Best Software for buring discs
What do you use to make back up data dvds or cds from the mac. I want to delete a pile of data onto DL dvds but need the right software as disk utility doesn't cut it.
v |
On the Mac platform, Toast is the most highly recommended burning software. However, using Disk Utility to create an image and then burn that image to a disc is the most bullet proof way of burning data I know of. The drawback to this method is that it creates Mac only compatible discs. Whereas Finder of Toast will create "universal" discs. I have never (knock on wood) had a Disk Image/Disk Utility back up disc fail to load. Prior to that, if I go back say 6-years, I have about a 20% disc fail rate on back ups. Meaning the discs simply don't load. All these disks were verified at the time of burn and have been properly stored.
Mike |
