Help me Spec. an Editing Computer
I have reached a point where my present computer is really at it's limit as far as editing and rendering is concerned. Presently I am using a 4 year old Dell 350 Workstation. It is a single processor at 3Ghz and has 1Gig or ram and two SCSI drives. One 36 MB and the other 73 MB. I also have 4 external drives totaling 2.5 TB linked to it via 1394 cards.
There is no reason to upgrade the 350 as the RAM is outrageously expensive ($1,000.00 for another Gig) and I can keep it as is for other jobs. I edit using Sony Vegas Movie Studio Platinum (ver 9.0) The Sony program is perfect for the type of work I edit. The projects are from 10 minutes to 55 minutes in length and I often have to cut different versions or short segments from the long version. In some cases I have had as many as 6 short versions edited from the long version. I don't need a compter with huge internal storage. I would prefer a computer with one boot drive with the programs on it and a second drive to keep current work available. I archive the other edited programs in external drives for recall if necessary. Everthing is live action. Graphics are just basic titling. I do not do any involved graphics or 3D modeling. My biggest bottleneck is rendering. Each finished project has to be rendered into almost every release format including AVI, Quicktime, Real Media (in 2 versions), MPEG, and WMV. In the future I may be ask to do DVIX and IPod too. Once into rendering my current computer is useless for anything else as the system is max'd out doing the render; with WMV being the major culprit in terms of time. Taken to the extreme I occassionally have the long version and 5 shorts to render into a minimum of 5 formats. I can blow most of a day just rendering. With a new computer I would edit and render in the faster unit. Copy the files into an external drive and connect it to the current computer to feed my DVD burner or upload it to my clients server. I am currently working is SD format, but I have the ability to shoot 16 X 9 and HD 1080 formats in the future. I have had good service from my Dell computers (I have 4 in all) and I plan on staying with them. I typically purcase from the Dell Outlet side and get refurbished units. They are cheaper and the guarantee is just as good as a new one. I am confined to what comes down the pike; but in talking to a Dell rep I can place a set of specs with him and when one comes up that matches or is close he will call me. I will get either a series 5400 or a 7400. I have to purchase the computer as configured by Dell. I want a good solid configuration of processor and video card. Here are my questions. Where in the computer does the rendering take place? Soley through the processor or in conjunction with the video card? Will a high end Quad Core or Dual Quad Core computer allow me to render and edit a different job at the same time? Or, will it get bogged down in the render no matter what? Processor. Should I go with a Quad core or Dual core processor to save a few bucks? Many Dells get built with dual Quad Core processors. Is there any advantage of getting a dual processor unit with say (2) 2.0 or 2.66 Ghz Quad Core processors vs. one 3.0 or 3.3 Quad Core processor. Memory, I have been told that 4 Gig is the minimum. More is probably better but, how much is too much? I ocassionally see them with 16K and 32 K of memory which is probably overkill for simple video work. Video Card What minimum should I be looking at 256 Mb or 512Mb. A few 768Mb computers are available as are dual 256Mb and ocassionally dual 512Mb set ups. The most monitors I would feed are two. Almost all of the singe cards will feed two monitors. Also, in reading about the capabilities of the video cards; many seem to be designed for CAD and 3D graphics. Is this beyond what I need for video editing? Or, will the added capability transfer to speed regardless of what video the card is processing? Are there manufactures to include or to exclude from consiteration? Are there video cards specifically designed for video editing work? If so what are they (brand & model)? Hard Drives I am figuring one smaller drive (80 to 160 Gig) for programs and a second one (250 to 500 Mb) to hold the current active files. The Dells will hold up to 4 internal drives and I can add as necessary. This is an upgrade that my Tech can do so anything with two drives is a good start. Will standard SATA 7,200 RPM drives work internally or should I go to 10,000 RPM SATA drives? Any other pointers would be helpfull. What I need is a good workable computer at a reasonable price. I cannot afford to buy a $5,000.00 computer. In monitoring the Dell Outlet site I see lots of good computers in the $2,000.00 to $2,700.00 range. Thanks, Michael |
Big list...
Depends on your operating system. If you are running a 64 bit OS, then 16GB is probably where I'd stop. But memory is relatively cheap compared to CPUs, so take care of that first. Quote:
video editor specs
I recommend you study the several articles at videoguys.com on building your own video editing workstation. There's a wealth of knowledge to be gained -- even if you don't intend on building your own. You'll likely find the answers to your questions. I'm not meaning to discourage you from asking questions. It is just that I find the videoguys website to be a really great place to start.
Charles |
Thanks to both of you for taking the time to answer my questions.
I have been in the business all my life (I am just turning 65 in a month or so) as a producer and director. I can edit motion picture film but, when video came around I worked with editors who ran the equipment in both linear and non-linear. Now I have learned NLE and I love doing it. I am not a tech oriented person; hence the laundry list of questions. |
