resampling
What is the best way to resample minDV (4:1:1) to 4:2:2, b/c I understand it yields better qulity/better chroma-keying? I also heard that canopus A/D convertors can do that? Can anyone shed some light? Thanks.
Do it digitally. A lot of the good keyers will upsample 4:1:1 to 4:4:4. Which NLE are you using and on which platform?
I have Adobe Premiere Pro, After Effects 6.0
How do I do it? |
Does up-sampling create a better image for chroma keying or does it produce banding? I'm not sure, because I've seen mixed results. Any links on this topic?
I'm pretty sure After Effects has a good keyer that will do the upsampling. I'm not familiar with AE so others can fill in here.
suppose your values are 1 2 3 4. You brighten by 50%. That gives: 2 3 5 6 (round up) Reduce the brightness by 33%. That gives 2 2 3 3 On a large scale this should cause bands of the same color to appear. Banding is avoided by using big intermediate numbers (i.e. 32-bit floating point numbers). Does upsampling create a better image for chroma keying? Yes according to Adam Wilt's DV FAQ. http://www.adamwilt.com/DV-FAQ-tech.html#colorSampling |
