One Camera Or Two?
If you had a opportunity to buy one XL1S or two XL1's for
a little more would you? Meaning, for shooting live musical performances I can get multiple angles. Or, is the XL1S that much better that I should stick with one. Any input? |
get a dvx100 and a dvc30 as secondary..... ;)
1 is a neccessity. 2 is a luxury. do you need 1 or 2?
Thanks for responding. I want to explore all kinds of things but
one situation is for sure, I run a large, multiple theatre complex where there are all kinds of events, most of which will be live, one take, situations and I want to be able to provide creative videos of the performances. I don't know how you could achieve that level of diversity with just one camera. If the XL1S is much better than I would opt for a second one later or somthing else as a second camera but from what I've read it's hard to match color. I mean, is there a way to obtain multiple shot angles for a live performance? I don't see how. |
I guess the only way I could see doing one camera is using
fillers in between shots with audio obviously recorded separately. Any other options? |
I think in your case I would go for the two cameras. The s model is a little better, but it's sort of like the PD170 vs. the 150...minor improvements, but nothing earth-shattering. The S/N ratio is a little better in the s model, I think, and a few other little things, but nothing that make the older one obsolete.
If you're buying used cameras, be sure to check out everything very carefully...record something with each one if you can, then play the tapes back on another camera or deck to make sure there are no head alignment issues, shoot some black with both and check for little white or colored spots that would indicate a bad pixel, etc. |
Two DVC80s!
I'd go for two cameras if you are going to shoot events regardless of brand or model.
However, if any of the live performances will be at night, I'd suggest you take a strong look at the VX-2100 and PD170. Much better low-level light performance. I was reminded of that today when I shot several movie scenes in a blacked-out comedy club with only candles for light. The candles are bright spots but not blobs and no vertical smear lines either. The actors, including several with dark skins are clearly imaged. |
Thanks Mike, that's the kind of input I'm looking for before
dropping the cash. |
Would it be tough to use say a pd-150 and an xls1
together? Most of my 'low light' situations are going to actually be well lit light shows - no candles. These events will only be a small part of what I intend to shoot, I will do plenty of daylight work and want that warmth. I'm buying so your input will have it's place in waht I create. Thanks for all your responses! |
Warmth is a setup issue or white-balance or a post production filter. You can get what you want with any camera, one way or the other
Color matching a Canon and Sony has been said to be difficult. I shoot with a DSR-300 and a PD150 or two for stage events. The prosumer cameras are OK but nothing handles as fast as a pro camera with lots of buttons that are immediately accessible and lens elements that can be operated directly. The 150 (and the 170) have less high-gain noise but the DSR-300 image processing is superior and delivers a richer picture IMO. If I were going to buy a new 1/2" camera, it would be the DSR-390 which has 170'esq low-light capability coupled with even better image processing. Oh, and the 3 hour tape load is nice too. |
Save yourself some grief and get two cameras of the same type. You will be much happier in the long run.
I did what you are considering, bought two XL1 cameras instead of one new XL1s. Much better business decision. Besides giving multiple angles, you have a backup if something happens to your main camera. It's a good thing. |
I would love to 1/2" but in time.
I don't think I'll be stuck with the one or two camera issue. My thought is to go with one XL1S now as I can pick up another in a few months and my need is not immediate. I'm not concerned about waiting for an XL2 because considering two of those price wise puts me into considering another level of camera. I guess I'm I'm really wanting to know that the XL1S is truly a superior camera to the XL1. XL1S prices appear to be dropping. One site did show pictures of the differences in the two under low light condiitons and the XL1S appeared to be much better. They weren't selling anything, just a comparison. Again, I can pick another one up in a few months. ThoughtS? |
Wow, that DSR-300 is nice though, I'll give you $3000 and
my wife? Nice little Italian girl, a little mean but striking! |
The XL1s is a little better and those who have used it say it's a little sharper than the old one. If you don't have a camera and are going to buy a new one, then the S model would be the way to go if the old one were still on the market new. I personally would always go for a new camera over a used one, unless I had been well acquainted with the owner of the used one.
You can balance an XL1 and PD150 close enough for your purposes, most likely. You go into the menu of the 150 and crank up the saturation and you'll be close. What you can't do is use the two for something like a 2-camera shoot of a speaker where you'd cut from a medium shot from one camera to a closeup of the other. There would be a fairly big difference. However, you could shoot a reverse angle of the audience with the second camera and it would work fine. If you're getting interested in 1/2" chip cameras, I agree that the DSR300 (now the 390) is the best one available. It's also the most expensive. There are, however, two others that are significantly cheaper--the JVC GY5000 and the Panasonic DVC200. I think it's DVC200...something-200. The JVC has a flip out screen that none of the other pro cameras do (yet). The Panasonic only uses the full size cassettes, while the JVC and Sony use standard and mini. If you don't need to have two cameras right away, then your idea of getting one now and then another later is the best plan, in my opinion. You might also want to look at the PD170 and the Panasonic DVX100a. Both are 1/3" chip cameras like the XL1s, and every one has some advantage or disadvantage in relation to the other. They are all fairly close in image quality. There's also a JVC (something)-300, which is a 1/3" chip camera that nobody ever seems to talk about much. Its specs show a higher resolution than the other 3, and it's cheap...but it gets no respect. |
| All times are GMT -6. The time now is 09:23 PM. |
