stock footage recommendation
Hi, all!
I am looking for stock footage of - white dove flying - whole body visible - white dove standing/walking - close up if possible, both in slow motion, both with chromakey so far I found http://www.efootage.com/ (search for white dove ) which footage is OK for the flying part altho a little steep at $40/second. Do you have any suggestions for a good stock footage library? Or, should I consider renting/buying a white dove and have it fly in front of the greenscreen I own? Any experiences with a similar project? (I plan to use DVX100A in 30p so that I have at least some advantage if I decide to slow it down.) Thanks! -- Andre |
Artbeats has a beautiful white dove shot in High def (available in SD) on their site, look at the worship library.
www.artbeats.com |
Andre: I've moved your thread to the approriate forum.
Thank you
Thank you, Spot.
Rob -- I stand corrected, and educated. Cheers -- Andre |
