16.9 mode
I have been using my XL1S, PD170 and PDX10 all in 16.9 mode for the last year. I have not had any problem. I realize the cameras are not made for this but the results has been good. My question is would any one watching my videos now the difference between these cameras or if I used XL2? I am thinking of buying the XL2 but do not want to spend the money if I do not have to. In addition, I hate logging the Canon with me because it is so heavy Help J
Why would you buy a new camera because someone else might
see it is not "true 16:9". Work with what works for you. If it looks good enough to you, that is all that matters. In the end, story, acting, music/audio, lighting, composition and editing are for example much more important than true 16:9 or not. |
The PDX-10 is in fact "true 16:9" but the PD-170 and XL-1s are not. If you compare the footage on a good screen I think you'll see the difference. Of course it depends on the nature of what you're shooting. I have a VX-2000, which should be comparable to your PD-170, and a PDX-10. I can definitely see a significant difference in 16:9 quality between these two cameras. Here's a test that I did: http://www.greenmist.com/dv/16x9.
The XL-2 should give even better results, based on sample frames that I've seen. Its ability to shoot in progressive scan mode (24p and 30p) will give you another boost in resolution. It also offers much more control over the image than your other cameras. As you point out, it is expensive and heavy though. Another possible option to look into would be the Sony FX-1 which is less expensive and can shoot true 16:9 in DV mode plus 1080i HDV. But I think Rob has given you good advice. If you're satisfied with the results then why switch? My only caveat would be to make sure that you've viewed your footage on a good 16:9 native monitor because that might reveal problems which you can't see on cheap screens. |
Thank you.. I appreciate your help...
