Pal Output
Curious, if you're working in Final Cut Pro but shooting in Pal is there a way to output from Pal to NTSC from FCP without using an outside program or service?
-Vinson |
FCP cannot be used to convert PAL to NTSC or vice versa. However, it can be done through Quicktime but the results are for entertainment purposes only. By that I mean I wouldn't show the end result to a client or use it for any critical work or evaluation.
Jeff |
Thanks for the quick response. When you say entertainment purposes I suppose you don't mean television replay or do you? Is it just totally crap?
-Vinson |
Entertainment purpose is a cheap way to see what you've got before you pay to have it done by a post house. In no way could it be broadcast, it's just for you to see what you've got.
Jeff |
