4:3 and a 16:9 issue - HELP!
I totally screwed this one up. I had used two cameras on a shoot. Both of them were to shoot in 16:9 mode.
Well, this was my first time shooting and the 2nd camera was in the 4:3 setting. (Yes, I've learned from my mistake!) What can I do to get some footage out of this blunder? I've never edited two different ratios at the same time. Can I cut the top off the 4:3 and capture? Any help is very appreciated! |
Sure, you can crop it no problem, you might have to soften up the other stuff to match but it wont be a big deal... just watch your framing on the cropped shots, you may, at times need to tweak the cropped area...
ash =o) |
I can always rely on you for great answer Ash. Thanks very much.
Would I crop in my NLE or in some other program. I'm hoping in my NLE. I'm using Avid. |
Do it in your NLE, that way you can preview the crop and adjust the framing to make it look nice (as Ash said) as if you just crop the top and bottom you'll likely wind up with bad composition - heads cut off, etc.
Awesome. Thanks. I bought a book on Avid, sort of a reference book, and I'll find out how to crop in Avid. Thanks again!
I'm not sure if this relates as I have not used Avid in two years. For extra measure I think you could set your render sub option for 16:9 just to make sure. I know Premier and Vegas offer this. I've done it before and it matched up without any noticable difference.
Just a random thought ...
Rather than crop, you may find it easier to just mess with the scale and position. Cropping would probably take more thought. |
Like I said, I'm not sure if it will translate on Avid. Vegas offers a render template and it will render everything in your time line as 16:9. I've used it will clips shot on a PDX-10 which uses extra pixels for a more true 16:9 and a PD-170 which does not. It matched up very clean, that is to say the PDX-10 was matched to the PD-170. This is not turning 4:3 into true 16:9 it is only simulated. It looked good and solved my problem. Let me know if you need anymore info, and good luck!
Hey nice! I'll check it out in Avid. :o)`
