NTSC DVDs in PAL regions?
Hello,
I've been reading that NTSC DVDs will play fine in PAL regions such as Europe, the UK, etc. -- However, occasionally some older tv sets will not display them properly. So I just have a couple of questions: -Is this still a problem nowadays in 2010? -- Or can I safely distribute an NTSC DVD in a PAL region without worry? -Will there be quality loss if someone plays an NTSC DVD on their PAL DVD player and tv? Thanks, Alex |
The last information I had on this topic was that VIRTUALLY all DVD players in PAL countries now ship with the ability to play NTSC discs by converting to a PAL compliant output signal on the fly. SO... ASSUMING your intended audience has a newer (I don't know HOW new it would need to be...) DVD player AND is ok with the quality hit that a consumer device doing the upscaling takes, you're ok.
Addendum: the image will be less sharp and colours won't be PRECISELY the same and there may be some motion blur/judder imposed by the retiming from 29.97 to 25 frames per second... |
I made NTSC dvds for my inlaws back in 2005. Their system is PAL. Even at that time, every PAL player I saw could play NTSC.
it works...the television is not the issue, the DVD player is. And all players support NTSC in PAL regions. I live in India, a PAL region, but where commercial DVDs are sold as NTSC.
You could, but the purist in me prefers a PAL disc.
Recently I had a client tell me how she had called the USA to purchase a DVD and checked with the merchant that they had a version that would be PAL format for Australia. She was disappointed when she still got a NTSC disc through in the end ... and I ended up doing a standards conversion for reliable playback. Just sayin' ... Andrew |
You're taking chances
Although practically most players will either play both standards and output whatever you feed them, or they will convert to PAL - there is no guarantee that ALL your clients will be able to play back your product.
If this is a professional job, then I suggest you do the transcoding and play it safe. |
Especially if you are producing something such as a guitar tutorial and there needs to be clear view of the motion of the fingers, etc. A good quality standards conversion will carry this through whereas the job done by a consumer DVD player is .... cheaper.
Andrew |
