Firewire Port isolator (where to buy?)
FireWire Port Isolator - 6pin - 6 inch
Anyone know where to buy these in the UK, ive searched google and yahoo. With no joy! ;-( Thanks Andrew |
I don't have an answer to your question ...
But maybe you can do it differently. The only difference between a six pin Firewire connection and a four pin one is the power. All camcorders use a four pin connection. So a six pin to four pin cord will never carry power ... HTH GB |
Actually, not all camcorders use a 4-pin FireWire port. I believe the HPX170, for example, has a 6-pin FW port.
Kevin |
Hi
Thanks for the reply. I've got the jvc gyhd110. I think its got the 6 pin. Thanks Andrew |
Hi, Andrew...........
You can achieve your objective with these two:
Firewire 400 6pin to 4pin Leads : Firewire Cables : Maplin That one gets rid of the power. Firewire 6pin to 4pin Gender Changer : Firewire Cables : Maplin That one takes you back to 6 pins again, without the power. Job done. Maplin is everywhere. CS |
Even if you go with this cable or another combination, I would not risk connecting the GY-HD100/110 while it's on. JVC admits that it has a problem with that port, and the only recommended connection strategy is to NEVER connect a cable while either device is on.
FW ports on pretty much any camcorder are delicate and should be used with maximum precaution. |
I know, i've read alot on this forum about powering on the JVC with the power off for both items.
Thanks for the correction on six pin camcorders -- the premise holds the same though, use a four pin connection at some point in the route and you'll have eliminated the power.
Cheers, GB |
Asda price
2 Attachment(s)
Sorry for coming a little late to this thread, but I knew I had this gadget somewhere. Now I've found it - a retractable 4/6 pin FireWire cable from Asda. I bought this just over a year ago (can't remember how much but I think it was quite a bit less than £10).
Perhaps not the highest quality for repeated everyday use, but it works OK. Sorry for the low quality iPhone pics - the circular sticker reads: ASDA MODEL NO: WM065 DESCRIPTION: IEEE 1394 CABLE KIT PRODUCED FOR ASDA STORES LTD, LEEDS LS11 5AD 388/105 |
edit, figured out
