Need Help Testing MPEG-1 File
I have been working with the tech support at Sorenson regarding a problem with the MPEG-1 files that Squeeze 7 is making. I am having trouble convincing them that there is, in fact, a problem. The MPEG-1 files that come out of Squeeze are not playing in most Windows Media Players that I test them on. They play on some, though, and the some include the players on the computers that Sorenson tech support uses. I have sent this video file to three people, and it plays on two out of six computers so far.
If you have a moment, could you download this MPEG file and tell me if it plays on your PC with Windows Media Player? http://members.dslextreme.com/users/.../Test10sec.mpg I do not need it tested in Quicktime, I know it plays there. I need results for Windows Media Player, whatever version you happen to have on your computer. Then please post your results, and, if you can, include the version of WMP you are using. You will probably have to right-click and "Save Link As..." to test WMP properly, as clicking on the link will play it in whatever plug-in your browser is set up for, such as QuickTime. The problem is not making it work on my computer, per se. I have to send MPEG files to dozens of different clients who use WMP, and I can't ask them all to upgrade, re-configure or change their media player. That is bad business, and in fact it should have to happen at all. I have been making MPEG-1s for many years, and they are basic, non-proprietary, easy to use files that should just play. If I can get a decent sampling of responses, that would help us solve this problem. Thanks a bunch. |
Re: Need Help Testing MPEG-1 File
Plays in WMP 10, v 10.00.00.4074.
Windows XP But, this box has ffdshow on it, and I see that the codecs were supplied from ffdshow. |
Works in version 11.0.5721.5280 no problems.
Windows XP SP 3. CS |
Does NOT play in WinMedia Player on my Windows 7 computer (latest everything).
[It does play in my QT-based MPlayer Classic, but you already know that]. |
Nogo on any of my 3 Win 7 PCs.
[QUOTE=
But, this box has ffdshow on it, and I see that the codecs were supplied from ffdshow.[/QUOTE] That's very interesting. I've been telling them its a codec problem. This appears to be a DivX/MPEG-4 codec. Thanks everyone for the replies. They are very helpful. If anyone else wants to post their results, that would be even more helpful. |
Nope, it's not Divx - it's mpeg1. Here is the report generated by Media Info.
General Name : Test10sec.mpg Format : MPEG-PS File size : 1.69 MiB Duration : 10s 560ms Overall bit rate : 1 343 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 1 Format settings, Matrix : Default Duration : 10s 477ms Bit rate mode : Constant Bit rate : 1 058 Kbps Nominal bit rate : 1 100 Kbps Width : 352 pixels Height : 240 pixels Display aspect ratio : 4/3 Frame rate : 29.970 fps Scan type : Progressive Bits/(Pixel*Frame) : 0.418 Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 10s 560ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 1 channel Sampling rate : 48.0 KHz Resolution : 16 bits |
Plays OK on my Win 7 Ultimate, version 6.1.7601 SP1
Windows media player version 12.0.7601.17514 last update was 11/2010 GSpot shows using mpeg-1 codec, but I don't know whose. I have a bunch of codecs installed.... fwiw, plays ok in vlc media player also. |
Something is wrong either with the way the file has been encoded or some header info. According to Information about the Multimedia file types that Windows Media Player supports mpeg1 is supported in Media Player 9-10-11, but there is some conflict with Media Player under Win7. The file plays fine on all my video players except WinMedia Player. |
Doesn't work for me either. Window Media Player ver 12.0.7600.16667
Windows 7 Home 64 bit. Gordon |
Running Win 7 64 bit enterprise and it plays just fine with latest WMP 12. Just to let you know, I do have VLC player on my system as well.
Good morning Ken. Your video works fine on my Toshiba laptop running window vista ultmate 64 and WMP version 11.0.6001.18311. Hope this helps...
Works fine in WMP 9.00.00.4510 on XP Pro.
This particular box doesn't have the ffdshow codec package installed, but does have VLC. FYI, ffdshow is installed with Sorenson Squeeze, and provides various encoding and decoding support for Squeeze. Any MPEG-1 incompatibilities would seem to be codec differences, possibly the ffdshow version of MPEG-1. ***************************************************** Works fine in WMP 12.0.7601.17514 on Win7 No ffdshow or vlc on this box. ***************************************************** I think I understand the reasons you're distributing in what is today considered a low-quality-for-bitrate codec, that there is near-universal compatibility with this format. However, the world has moved on, and what worked yesterday may not work tomorrow. Standards organizations and all sorts of manufacturers are promoting the heck out of various MP4 versions. We're now two generations past MPEG-1... Take that for what it's worth. Squeeze has some great workflow and batching capabilities, and gives access to controls that many other encoders don't. However, it's not the only product out there, especially if you don't use all of its goodness. Telestream Episode is perhaps equivalent. I've heard good things about (Grass Valley) Canopus Procoder, thought I've not used it myself. Likewise Carbon Coder ($$$), and Compressor on the Mac. If you don't need batching and sophisticated controls, there are a lot more encoding products out there... |
I choose Squeeze because it can handle AVCHD files (and others), I can set up many files and run it overnight, and it makes use of my Mac's 8 cores (but not hyperthreading). It will work with a reference file from FCP so I can join files that way, although that's annoying. In any event: Is there any way to install a new codec in my encoding software? Either by me or by Sorenson? That seems to be the best solution. |
I think the mpeg1 file Sorenson is producing is fine; neither G-Spot nor Media Info report any problems. As pointed out above, it's just that Microsoft does not consider such an old codec important anymore, so it plays in some versions of WMP and it does not in others... they just don't care to fix it anymore.
As far as other encoders, consider TMPG - it's one of the best kept little secrets in the industry. It's a consumer priced piece of software with pro capabilities - high quality encoding, batch operations, clip joining, filters, even timeline-based basic editing - all this for $100. Yes, that's no typo: one hundred! |
