Two seperate 25fps videos wont sync up
I'm currently trying to edit a live event and sync up the two cameras so I can do a multi-cam edit, but one of them seems to gradually speed up slightly (like it shows 2 frames before the other one), like it's 24fps or something, but it Premiere says it 25fps.
I try and re-sync up, and it just eventually starts to slip out of sync, any ideas? |
Re: Two seperate 25fps videos wont sync up
Ah, I think it's because one was progressive and the other was interlaced for some reason and Premiere is reading it as 25fps because it is just interlace with 2 fields.
I'm guessing the best option would be to convert the 50i one to 25p? What's best way of doing this? |
You could do a batch conversion in MPEG streamclip or put all the 50i footage on your edit timeline and export it as a 25p version.
