LCD screen flicker removal
Hi all,
I shot some footage in an office building recently and stupidly forgot to change my shutter speed to eliminate the flicker of an LCD display that was in shot. Does anyone know of any methods to eliminate/reduce the flicker in post? I've done a bit of research and haven't found any useful info.. hopefully someone here has some answers! Unfortunately reshooting isn't an option. And while fixing it doesn't seem likely, I'm hoping there's some magic solution out there! Thanks in advance. |
Re: LCD screen flicker removal
Was your camera locked off? Is the screen unencumbered by any objects moving in front of it?
Andrew |
I was hoping for some sort of plugin which detected and eliminated the flickering, but I guess most things are never that easy :) |
I thought there was a plugin in beta recently.
This probably won't be it, but might be worth a try. Flicker Free - new deflicker plugin for Final Cut Pro X and Adobe Premiere! - motionVFX Blog Andrew |
Thanks for that, I'll give it a try.
