October 16th, 2016, 10:23 PM | #31 |
Re: Mini DV tapes from camcorder to computer
It has been a while for DV and HDV, hasn't it? I'm looking at this HDV deck sitting on my editing desk, and realizing it's probably been over 12 months since I shoved a tape in it. Maybe a lot longer...
30 years of pro media production. Vegas user since 1.0. Webcaster since 1997. Freelancer since 2000. College instructor since 2001. |
October 17th, 2016, 01:33 AM | #32 | |
with the PC running or not: 1) connect the firewire cable to the port on the computer first, (mine is normally permanently there)The risk with firewire connectors (both 4 & 6-pin) is that the data contacts are not recessed so they can be the first contact when mating. Now most desktop computers are connected to ac supply ground through their 3-pole IEC connectors. Most camera charger/PUs as travel-friendly devices are however double insulated so don't have a ground connection. This means that when ac connected, the camera 'ground' (i.e. firewire socket shield) will normally have a low-current floating ac voltage caused by leakage currents in the PU circuits. Whilst perfectly safe for human use, this current can damage the driver/receiver circuits in the interface if it is presented when the shield is still unconnected between the two devices. Once connected though the interface is as robust as is needed and connecting the camera power supply will allow the two device grounds to be clamped together via the shield. The DC port for the PU is of course quite robust as it passes through power regulators before reaching any sensitive circuits. |
October 17th, 2016, 01:25 PM | #33 |
I'm concerned about 7.5 gigs being all that is left on the Mac. How big is that drive in total. My rule of thumb is ANY drive is full at 80% capacity. I know some guys will go to 90% but I don't like it that high, especially if is is an OS drive. It sounds like some drive maintenance may be needed if you want that Mac to continue to perform well.
Kind Regards, Steve
www.CorporateShow.com Been at this so long I'm rounding my years of experience down...not up! |
October 17th, 2016, 01:45 PM | #34 |
The other risk is that 6-pin firewire connections carry power. Which is why the most conservative approach is to power down the host computer, particularly important in multi-user environments.
October 17th, 2016, 04:54 PM | #35 | |
You will see that I suggested connecting the PC end of the cable first before the camera. Any fumbled temporary mismating wouldn't harm anything as the cable would be open circuit at the camera end. I don't see how a multi-user environment would increase the risk to cameras providing anybody using the workstation was familiar with the correct sequence for connecting up. Presuming that the OP has 120vac equipment, the floating voltage on double insulated unearthed equipment is about half that in the UK. In 18 years of connecting cameras up to firewire using the above method, I've never had a single damage of the interface issue. I accept that the interface isn't up to current ESD protection standards, but it isn't that fragile otherwise it would fail with any handling, powered or not. |
October 17th, 2016, 08:16 PM | #36 |
Well, I can certainly respect that you've gone 18 years without a blown firewire port. Me too, though I've taken an approach in my own work closer to yours in most cases - if there's no power on the 4-pin side, why worry about it?
That's going back to the early years of firewire - maybe more like 16 years for me. But, don't underestimate how smart human beings can screw things up in groups! On the human factors side, there's good reason to create SOPs that include powering down all the devices. Not every camera *is* 4-pin, for one. Was it JVC's HDV cams with 6-pin? Not every firewire hookup is *to* a camera. *People forget!* Duh, which end first? So, make it simple! I'm sure glad we're mostly done with firewire... I think the college where I teach got away with one blown port in a playback deck in about 10 or 12 years of firewire. That's not bad across hundreds of students using 6 cameras and 4 decks over those years. People can be a problem; you have to account for that in your procedures and plans!
October 18th, 2016, 08:50 AM | #37 | |
When powering down an edit station, that in itself can give a few issues, especially with external data drives connected. |
October 22nd, 2016, 03:38 PM | #38 | |
October 22nd, 2016, 03:56 PM | #39 | |
Later on , I read about people blowing ports , and it seemed only sensible to at least turn the camera off before connecting . I have a DSR 11 deck permanently plugged into my computer to capture DVCAM footage from , and keep meaning to get an HDV deck , so never need to connect my bigger camcorder at home ( still plugging in my V1e though ), but may rarely connect it to my MacBookPro if I need to do a quick edit away somewhere - in that case I plug in to the laptop end first , both powered off , and plugging into the camera I take care to ground the outside of the plug before plugging in . I just recently acquired three Firestore FS-4 devices , which also connect via FireWire , and have observed the same precautions when connecting them ( also 6pin to 6pin on the DSR or to the computer , but 6pin to 4 pin with my HVR V1e ) . The way I see it is , chances are no harm will be done , but it costs nothing to take a little care - so why risk trouble ? |
October 23rd, 2016, 01:40 AM | #40 | |
Nevertheless, you don't get a second chance and I'd rather start off with a dead system than finish up with one. |
October 23rd, 2016, 12:50 PM | #41 | |
Never blew a firewire port, but I totally fried my Titanium PowerBook G4 in 2003 connecting it to a "big iron" 12,000 Lumen Barco DLP projector with a DVI cable. The projector was connected directly to a breaker panel in the booth and the electrician didn't ground it. That was a real panic, as we were in the middle of technical rehearsals for this opera at the time: Il Trovatore (2003) – boydostroff.com Went right out to CompUSA and got a new PowerBook G4, but the Titanium had just been discontinued so I ended up with the first aluminum version. Only time I ever bought a new Mac immediately after release, fortunately I had a good backup to restore though. Was still running System 9 at the time and didn't switch to OSX until later that year. I recently got a Sony HVR-M15U and am in the process of capturing all my legacy DV/DVCAM/HDV tapes which number in the hundreds. It was the only thing I could find for under $1000 and works well for capturing, although there are some other oddities. The manual stresses to always power down both the deck and computer when plugging/unplugging the i.Link cable. |
