No audio with Sony DSR-25 and XL2
So we just got a Sony DSR-25 to capture temendous amounts of miniDV tapes. However, whenever we try to play back a tape, we're getting video just fine, but there is no audio.
The audio on the XL2 is set to 16bit and I'm getting audio just fine from captureing from the XL2. Do I need to set the DSR-25 a particular way? Thanks. |
Anyone?
Brian, what kind of NLE are you using? I assume you are capturing via the DV jacks?
When you say there is no audio, is that from the phone jack on the DSR-25, or from the captured video? Is the Input Select switch on the DSR-25 set to DV? This shouldn't make a difference on playback, though. When playing a tape, move the Display Select switch to Audio. You should see the audio meters for channels 1 and 2 superimposed on the DSR-25 LCD. Is there a signal being detected? Check your capture/DV device settings in your NLE. It should show the DSR-25 as an option from a list. This will ensure that the NLE can control and communicate with the DSR-25. Read through Chapter 2 of the DSR-25 manual, particularly on Connections for Playback. BTW, you mentioned that you recorded 16-bit audio on the XL-2 and got a picture only from the DSR-25. I assume that the recording speed was SP, too? Hope this helps. |
Something else occurred to me. Did you use different cables when capturing from the DSR-25 and XL-2? A faulty cable or loose or damaged connection could be at fault, however unlikely.
