Transfering Betacam to mini dv?
Hey there!
I will be doing a shoot with Betacams and mini dv's, and need everything transfered to mini dv. The camera im using is a DSR-709! Unfortunetly it only has video out, no firewire. Would I just plug the video out into a monitor, and plug a minidv camera in and capture it using video in? How much quality would I lose doing it this way! Thanks guys! |
One would loose a HUGE amount of quality doing it that way, one would wonder why you'd shoot Betacam and then do that. Even DV would suffer being transfered that way.
The simplest way is to play the tape out of say a Sony J30 deck down firewire into a DV deck and record. To my eyes you can get a slightly better transfer taking the SDI output from the deck into the SD Connect from Convergent Design, let it do the down convert to firewire and then record that. Regardless though I have to question the wisdom of spending the money to shoot on the 709 only to then downconvert to DV. There's plenty of very good DV cameras such as the 570 that are native DVCAM. I've done many betacam to DV conversions however I'm working in PAL and the output was DVD so the loss in the color sampling during the downconvert was barely noticeable in the final product. Working in NTSC might be a different matter. |
Don't do it from the camera - preview out only, really. Get a decent SP deck and connect it via component cables to a high end DVCAM deck that accepts component input. Make sure that the video levels are correct - you may need a proc amp for this, and dub. I'd just pay a facilities house to do it for you.
Above advice about J30 is also a very good route. But really, you'd have been better off shooting direct to DV and avoiding SP altogether. Graeme |
Thanks for the replies!
The reason im spending all this money, is because my old man owns the camera, so im not spending anything!!! The tapedeck is the best option but the cost .... ahhh the cost!!! |
Just use a local service to convert betacam to DV
I use a local service here in Miami (Accord) everytime I want to convert from one format to another. They have very high quality betacam and every other kind of deck and it usually cost me about $2.00/minute. Since I usually only get 30 or 40 minutes worth of beta sp its a lot cheaper than renting the beta sp deck for a day.
Yeah, 200/day for sony beta deck, or $35-50 per hour in a local shop. But never camera to camera. Yuck.
