Bill Pryor |
March 7th, 2003 07:35 PM |
The JVC is only DV.
I think it's a better idea to output your master to a deck rather than your camera. There have been quite a few incidents in which the person shot his footage, loaded it with the camera that shot it, then made his master to the same camera, and then took the tape to a dub house, and it wouldn't play on a professional deck. The reason--his camera's heads were out of alignment. I personally know of 3 cameras that have caused trouble in this manner. In one case, the guy shot an entire production in France. Then he somehow discovered that his heads were out of alignment, and he sent his camera in for repair. Not a good idea until the tapes were dubbed. But he didn't know better. Of course, what happened was when he got the camera back, now all adjusted to spec, it wouldn't play the tapes it had shot when it was out of adjustment. Nobody else's deck would play them either, even the high end DSR1800 and 2000, which will play most things even if they are a little out of tolerance. His heads had been way out.
So, if you have a deck and take a tape from your camera and play it in the deck and it won't play properly, then you know you have a camera problem and you will know it before it's too late. Then you can clone the tapes via firewire from the errant camera to the deck and then get your camera fixed.
Now, not to be alarmist or anything...but I know a person who bought a used DV deck and has made all these master tapes...and then found that the dub house couldn't play them. Turns out the DECK was out of alignment.
This is one reason professional decks and cameras cost what they do. So, unless you can afford those high end things, it's a good idea to cover your tracks whenever you can. Check your camera occasionally by trying to play a tape you've shot in somebody else's camera or deck.
