QT into Flash file
Can someone help me on this. In FCPHD l have completed a project and now need to convert to QT movie which will then be put into Flash. Should l make QT movie 720x240 at a high Res? Or is there a format for putting QT move into flash for good quality.
Ron |
QT to Flash
Try an app called visual Hub
you can just google it, and it seems to do a really great job. Create a self contained QT right out of FCP at the native specs that you've been editing with. Drag it into visual hub and use the presets, they work great. |
If you have the Flash Video Encoder plug-in for QT you can export .flv files at various resolutions and data rates, and crop and re-scale.
Thanks for yor help
Ron |
Thanks, I need to get that plug-in for QT |
you can also try on2.com
you can make a reference movie out of FCP (don't check the box that says "Make Movie Self-Contained") and import the ref movie straight into the flash encoder. that's how you do it if you buy the stand-alone flash converter. they also have a compressor plug-in (which i have not used, but their stand-alone works very well) which allows you to convert straight out of the timeline into flash. on2 wrote the flash 8 code, which adobe purchased and labeled, so you're basically getting adobe quality at a much less expensive price because you're only paying for a video encoder, not the fully-featured animation and web design adobe package. |
