16mm lenses on a mini35? at DVinfo.net
Alternative Imaging Methods
Old November 11th, 2004, 05:47 PM   #1
it's been a year and I know it is not supposed to work but has anyone kluged a 16mm lens onto the adapter? Just wondering.
Don't want to sell my 16mm stuff. Been holding out on random innovation....
Josh Brusin is offline   Reply With Quote
Old November 11th, 2004, 11:06 PM   #2
Josh, it won't cover the frame. It'd be like looking through a toilet paper roll, a circular image in the middle and black all around.
Charles Papert
www.charlespapert.com
Old November 15th, 2004, 01:08 AM   #3
yeah, I've popped a few on and seen that. I figured someone, industrious and availed with time, had come up with a solution incorporating a frensel and some duct tape...?
Oh well... Looking for super cheap and super fast cine-primes... Optars or sumpthin-somethin....
anyone? Chaz?
Old November 15th, 2004, 09:54 AM   #4
"super cheap and super fast" will likely only coincide if they are not so good optically (or actually hot property!)
Try the Russian lenses maybe?
Charles Papert
Old December 1st, 2004, 08:42 PM   #5
I think I may go ruskie. I do worry that those Kinor or Konvas lenses won't fit... any first hand use Charles?
Josh
Old March 5th, 2005, 10:43 PM   #6
16mm Bayonet Mount Lenses
We have recently invested in a XL2 with a mini35 300. We keep running across 16 and super 16mm lenses with Arri Bayonet mounts. We have also run across Bayonet to PL mount adapters. Can we use these lenses on our mini35?
Clint Gossett is offline   Reply With Quote
Old March 5th, 2005, 11:38 PM   #7
Barry Wan Kenobi
Not likely. The 16mm circle of illumination will be *way* smaller than the 35mm target frame size, meaning you'd just get a vignetted circle on the frame.
If the lens is PL-mount and designed to work on both 16mm and 35mm cameras, then yes it should work. But if it's designed specifically for a 16mm camera, it almost definitely won't work for a mini35 system.
Old May 19th, 2005, 07:07 PM   #8
16mm c mount to mini35
uh... I've been spacing several 16mm c mount lenses out and they seem to be able to cover. I am still messing with the zoom but so far so good. Has anyone jury rigged this yet?
Old May 19th, 2005, 10:30 PM   #9
The reason being.....? price? or.....?
Is it not Canon/Nikon good enough? Why 16mm lens on a larger frame?
Dan Diaconu is offline   Reply With Quote
Old May 20th, 2005, 07:05 AM   #10
As to the question of why you would want to do this... is it because you have 16mm lenses on hand, Josh?
Old May 22nd, 2005, 11:13 AM   #11
mostly because I have .9 angenieux primes for 16 and pulling focus with a 1.4 nikon is a B.
it would also save me $1000 for a pl ang. 25-250 (that's t3) and $250 for the adaptor... and another $250 for the bayo-pl adaptor....
when I have a c mount angenieux 12-120 on my shelf getting dusty...
Old May 23rd, 2005, 03:04 PM   #12
Sponsor: ZGC
Josh,
The 16mm format does not work on the Min35.
Take your 12-120 Angenieux, to see the real size of the image, all you have to do is close the iris to about T11 and have enough light on the scene to see that the image is limited to a small circle inside the 35mm frame.
Guy Genin.
Guy Genin
ZGC Technical support
Guy Genin is offline   Reply With Quote
Old May 24th, 2005, 02:39 PM   #13
i know... I was thinking to set it closer to the frame and while wouldn't zoom through get partial use of it.
If i didn't have so much going on I'd mess with it... was hoping someone else had by now...
