35mm converted to 2/3" Video at DVinfo.net
Alternative Imaging Methods
Old February 11th, 2005, 02:14 PM   #1
I was wondering what the conversion ratios are for 35mm lenes to video.
Is there a standard figure or does it change depending on the kind of lens, ie: Arri, Panavision, Nikon…
Also, can I adapt any Arri Bayonet to the Pro 35. I know th Pro 35 is standardized with a PL, but I have access to a huge variety of those lenes,
Brian
Brian Hamm is offline   Reply With Quote
Old February 11th, 2005, 03:38 PM   #2
Hi Brian,
Regarding conversion ratios, the beauty of the P+S Technik Pro35 is that there are none. The Pro35 preserves the focal length and depth-of-field of whatever lens you choose to use with it. Hope this helps,
Old February 12th, 2005, 03:37 PM   #3
While I do not believe the adapter has a bayonet mount as an option, You can buy an adapter to convert Arri Bayonet mounts to PL. Visual Products, in Ohio has them, and probably some of the other film equipment dealers as well.
Kindest regards,
Jason Brunner
jason@aros.net
http://www.jasonbrunner.com
http://www.fleurpost.net
(Thats just, like, my opinion, man)
Jason Brunner is offline   Reply
