Mini35/HVX200 at DVinfo.net
Alternative Imaging Methods
Old April 1st, 2005, 09:32 AM   #1
Mini35/HVX200
Well, it looks as to have the DVX form, let's hope it fits to our DVX rigged minis as easily as the XL2 did to the XL1 rigged minis.
Anyone have thoughts on HD Mini35? Are there any limitations in the Mini's ground glass compared to the pro? I'm thinking its the same glass....
Kindest regards,
Jason Brunner
jason@aros.net
http://www.jasonbrunner.com
http://www.fleurpost.net
(Thats just, like, my opinion, man)
Jason Brunner is offline   Reply With Quote
Old April 1st, 2005, 01:23 PM   #2
Hope...
I've been waiting for HVX200+mini35 rig for long time...
and that was the reason why I bought DVX100+mini35+Zeiss lens set...
I'll be really disappointed if Mini35 doesn't work for HVX200.
If anyone knows anything... please share it with us...
Please...
Jong W. Lee
Cinemasia Production
P.S. Is the name 'HVX200' right?
Jong W. Lee is offline   Reply With Quote
Old April 1st, 2005, 07:39 PM   #3
im using a mini35 with a fx1 and the image is amazing
Rafael Cruz is offline   Reply With Quote
Old April 2nd, 2005, 01:56 PM   #4
Rafael, how does focusing work out with the Fx1? Reading Adam Wilts review of the FX-1 made it sound like the FX-1's viewfinder isn't high-res enough to focus well for normal HD. I would assume it would be even harder with the mini35 on there.
http://www.sleeptightmovie.com
Dave Frank is offline   Reply With Quote
Old April 3rd, 2005, 04:36 AM   #5
<<<-- Originally posted by Rafael Cruz : im using a mini35 with a fx1 and the image is amazing -->>>
Would you mind posting some material?
Rabi Syid is offline   Reply With Quote
Old April 20th, 2005, 10:10 AM   #6
Rabi, I think if you do a search on the DV for the Masses Forum, someone already posted a clip, a music clip I think, shot with the FX1 and the Mini35 (or it's in the FX1 forum, don't really know anymore)
anyhow, there should be a link to footage of it via these boards.
Good luck!
Mathieu Ghekiere is offline   Reply With Quote
Old April 20th, 2005, 03:17 PM   #7
Go to Hmanvisions.com
Christopher Haring has a post under P+S technik and mini35 converters.
He shot a music video on hdr-fx1.
Harikrishnan Ponnurangam is offline   Reply With Quote
Old April 21st, 2005, 12:18 AM   #8
The HVX200 should work fine with the Mini35, according to conversations I had at NAB with both Panasonic and P+S Technik folk. However, sadly for those of us who own DVX relays--the front diameter of the HVX's lens will be larger, so that means a new kit for that camera.
Charles Papert
www.charlespapert.com
Old April 21st, 2005, 01:54 AM   #9
Thanks Charles, that's what I needed to hear:)
XL1s, XL2, 3x Wide lens, Matrox RTX 100 pro, Premiere Pro 1.5, After Effects 6.5, Encore, Audition
Dave Eanton is offline   Reply With Quote
Old April 22nd, 2005, 08:02 AM   #10
Does it mean simply a larger diopter attachment and reconfigured mount (probably $ hundreds) or does it mean a completely new kit (couple grand) ?
Kindest regards,
Jason Brunner
jason@aros.net
Old April 22nd, 2005, 08:59 AM   #11
Historically each new mount has meant a $2600 relay and mounting kit. This should be no exception. The shroud around the lens will need to be bigger, so all elements will require retooling.
Charles Papert
Old April 22nd, 2005, 09:29 AM   #12
Watch dog for HD
Charles,
I know you have watch dog for xl1 and xl2 and it has valuable links to mini 35 p+s technik. Is this same good for HDV cameras. I'm thinking of buying the HDR-FX1 i just want a link to put it together with Mini35.
thanks,
Hari
Old April 25th, 2005, 04:26 PM   #13
just curious, but does the mini35 relay lens screw to the lens on the DVX? if it does, you could probably just get a stepping ring to fit it to the new panasonic camera. From my understanding the relay lens is a just an achromat of some sort so you can focus on the GG... so you have to actually zoom with your camcorder.
just my .02cents
Cody Dulock is offline   Reply With Quote
Old April 26th, 2005, 12:33 AM   #14
possible, possible...however, as soon as you start to zoom back from full telephoto with the DVX you will start vignetting (in this case, the oscillating ground glass reveals itself in the corners. Sadly I've had this happen on a few shots by accident). Since the HVX has a larger diameter, it stands to reason that it will vignette that much more; however, it does have a longer zoom so perhaps it will cancel out this issue. It remains to be seen. Thanks for the interesting thought Cody, hope it pans out!
Hari, I haven't worked with it but I know there is a relay available for the two Sony HDV cameras.
Charles Papert
Old April 26th, 2005, 01:50 AM   #15
Well yes you will get vingetting with any 35mm adapter if you are zoomed all the way out. you usually have to zoom in to about 2x-5x depending on the camcorder and adapter. the reason for this is you are trying to record a 35mm camera image that is actually the size of 24mm/36mm.
