P&S adaptability with Super speeds at DVinfo.net
Alternative Imaging Methods
Old July 16th, 2006, 06:28 PM   #1
I'm about to shoot a feature project on the XL2 with the P&S. Someone told me that the P&S manual claims that you should not use Zeiss distagons below 40mm because they're not compatible with the system (cause vignetting, I guess?). Anybody know any other widely used primes with nice glass that would not have this problem?
Any opinions appreciated
Toby
Toby Watson is offline   Reply With Quote
Old July 17th, 2006, 09:33 PM   #2
DVi Contributor
I have seen this effect with these primes. it gets worse the wider you go it seems. However they made these primes for over 20 years?? and it seems that newer versions do not have the problem. so I was told to test each prime or try and gauge age by the serial number. Or go with more pricey newer glass. or go with 35 still lenes??
Craig Chartier is offline   Reply With Quote
Old July 24th, 2006, 08:16 AM   #3
I can't beleive...
... I've only gotten one response to what seems like a very simple question. Thanks Craig. I don't understand why the p&s has it's own stream when noone seems to know much about it.
Old July 25th, 2006, 12:33 AM   #4
Perhaps people just don't know about those lenses with the unit...
http://www.IndieRentals.com
RED Rentals, Camera, Grip, Lighting, Sound, Post and More.
http://www.madmojo.com
Production blog.
Eric MacIver is offline   Reply With Quote
Old July 26th, 2006, 07:45 PM   #5
2nd Unit TV
2nd Unit is going to be doing it's next documentary with the P+S over the next two months and we'll be reporting back on the perfromance with a number of different lens cobos on 2nd Unit. It's on this site under 2nd Unit television or at www.2nd-Unit.tv. If you can wait, I hope it helps.
Jonathan Ames is offline   Reply With Quote
Old July 26th, 2006, 07:58 PM   #6
I use Super Speeds all the time with the Pro35 and never had issues. I've used all focal lengths from 14mm to 135mm. Never tried the Mini35 though. I usually shoot 16:9 Digital Betacam (DVW-790WS).
www.digitalfx.tv
Greg Milneck is offline   Reply With Quote
Old September 12th, 2006, 10:33 AM   #7
yes, the problems are real
Just did a show using the mini 35 to mount various Super Speed primes to a JVC HD-100. The vignetting was heavy enough on a 25mm to render the lens unusable. The 40mm had some slight issues, so I ended up doing all my work with a 50mm and an 85mm, which worked beautifully.
Can't offer an alternative, but can confirm the importance of finding one if you need wide angle coverage.
Hope this helps.
Alex
Alex Bowles is offline   Reply With Quote
Old September 12th, 2006, 10:41 AM   #8
Those had to be standard speeds (max aperature of f2, T2.1). They vignette noticeably on 16:9 cameras up through the 32mm, barely on the 40mm and not at all on the 50mm up.
However, with T1.3 Super Speeds you're fine with the 18mm on up. We also have an Optar 14mm that doesn't vignette at all, and there are some options for wider angle lenses than that that won't vignette.
Production blog.
Old September 18th, 2006, 08:42 PM   #9
DVi Contributor
I'm still interested in wheather still lenes, such as NIKON or CONTAX primes also have this problem. If yor shooting with the mini, you probably can't afford to rent fast fresh hot off the line primes.
Old September 18th, 2006, 10:51 PM   #10
Generally, good still camera lenses will look good, with edge-to-edge sharpness because they're built to handle a larger film plane than 35mm motion film cameras.
However, where they lack superiority is in rack focusing, zoom, matched lens "feel" and common front element sizes.
It's also difficult to find certain focal lengths in still lenses that are as fast as film lenses.
That being said, they are a viable option for saving funds.
Production blog.
