Relay optimal setting? - Page 2 at DVinfo.net
Alternative Imaging Methods
Old January 26th, 2007, 04:21 PM   #16
Originally Posted by Michael Maier
with the HD100 P+S relay I found that it focus within a 6-13cm rage rather than 18.75cm.
I meant to ask you, are you saying you can retain full focus anywhere within that 6 to 13 cm range with your relay kit? Can you take a picture of your relay lens mounted to your camera? I'd be curious in seeing what that looks like.
What are the dimensions of your relay lens? Mine is approx 60mm in diameter and 50mm in length.
Dennis Hingsberg is offline   Reply
