Zebra workflow with the Af at DVinfo.net
Panasonic AVCCAM Camcorders
Old November 14th, 2011, 10:14 AM   #1
Hola,
just wondering if my workflow is correct in the use of Zebra Patterns. I mean:
-i set zebra button on then when the patterns disappear from the white areas i guess i well exposed area.
Is it correct?
I know that i have to buy the book and the dvd but i'll have to wait till next month
gracias guys
Old November 14th, 2011, 08:06 PM   #2
Re: Zebra workflow with the Af
Depends what you want your exposure to be, what your zebra levels are, and which one you're using.
Typical setup:
Zebra 1: 70-80% - typical level of specular highlights on caucasian skin. Levels will be 5-15% lower on black skin. Adjust exposure until zebras just appear at specular highlight points. Typically used when exposing for talent.
Zebra 2: 100% - pure white, nearly blown out. Typically used when you are exposing for environment.
Which you use and when you use them is ultimately up to you, of course - there is no hard rule on the "right way" to do it.
CAVEATS:
AF100 has been said to not deal well with highlights - overexposed highlights, especially when white balance is off on the AF, can get ugly fast.
- White balance properly
- reduce chroma levels (to avoid clipping individual color channels)
- use a scene file with a mid to low knee level
- don't overexpose and plan to bring up mids and shadows in post
www.mcbob.tv
Kevin McRoberts is offline   Reply With Quote
Old November 15th, 2011, 03:01 PM   #3
Kevin it's time to study hard this Pana!
Do u recomend the book or the dvd?
Many thanks 4 your support
Marcus Martell is offline   Reply
