Limited space, shallow DOF at DVinfo.net
Panasonic AVCCAM Camcorders
Old August 23rd, 2012, 08:20 PM   #1
I'm shooting a series of short lectures, delivered by a single person seated in her office (speaking directly to the camera), with bookcases in the background. I'd like to achieve a shallow enough DOF so that the bookcases have at least a gentle blur. Unfortunately, the office is quite small with max distance from subject to bookcases about 3 feet and distance from camera to subject about 4 feet. And I need a fairly medium shot of the subject (mid-waist to top of head). Would this be achievable with an AF100 and perhaps the Voigtlander 25mm f/0.95 lens?
Other specs:
Resolution: 1080/30p
Lighting: ample controlled lighting (5.6K fluorescent)
Audio: boom stand with mic
I can record audio to external recorder (Roland R44), so I suppose a digital SLR might be an alternative to the AF100.
Thanks in advance for any guidance you can offer.
Rob Brookler is offline   Reply With Quote
Old August 24th, 2012, 03:07 AM   #2
Re: Limited space, shallow DOF
Rob - the
should be fine, especially wide open. Here is an interview in a similar setting using a http://www.adorama.com/ZICP35FNK.html:
Good luck - and please let us know how the lectures turn out.
Cheers,
Bill
Hybrid Camera Revolution
Bill Bruner is offline   Reply With Quote
Old August 24th, 2012, 11:52 AM   #3
Bill, thanks very much!
I just noticed the Panny LUMIX G 20mm f/1.7 Aspherical Pancake Lens ... at about $900 less than the Nokton. Do you think this lens might be adequate for this job?
Thanks, Rob
Old August 24th, 2012, 02:54 PM   #4
Can you shoot from outside the door with a longer lens? For shallow DOF, you'll want the subject 1/3 distance from the lens (and 2/3 the distance from the background). There are also 'cheats' of hanging a large sheet of frost diffusion behind the subject. If you don't see reflections or creases, then it looks like a softened out-of-focus background. Another option is to go dramatic with lighting and put pin spot glancing across the books, but letting the rest of the background go dark. You'll need a grid on a softbox for your main lighting, otherwise, you'll be battling spill.
Oren Arieli is offline   Reply With Quote
Old August 24th, 2012, 04:04 PM   #5
Rob, I've used the 20/1.7 and Voigtlander 17.5 (as well as others) to do interviews in some very very small offices... often just from desk width distance, getting a medium.
25mm (like the PanaLeica 25/1.4) can work, but from a little farther away.
www.mcbob.tv
Kevin McRoberts is offline   Reply With Quote
Old August 24th, 2012, 06:13 PM   #6
Oren and Kevin, thanks! The door is mid-wall and opens out to a very narrow hall, so not much help here. But I can "reposition" subject and camera to get a bit closer to this 1/3 - 2/3 ratio. I had just ordered a grid for my softbox key, as the walls and ceilings are bright white so I'm getting all kinds of spill. I'll probably try the 20/1.7, based on all your input. If this doesn't do the job, I'll try something more "creative" with the background.
Thank you all very much! Rob B.
