Download DVC 30 Manual
You can download a DVC-30 manual at the panasonic euro. website below
http://panasonic-broadcast.com/index.cfm?uuid=A130E452C09F11269B89B84D8643F16D&pid=11436&catid=4287&ClassID=66 Hope the above link work. And also the some catalog at the link below http://panasonic-broadcast.com/index.cfm?EE7598DAC09F11269B8B4B8FFC2F09F4 if all link do not work you can visit the website below http://panasonic-broadcast.com/index.cfm then select product, select dv for dv camcorder, choose the model and download the require pdf. For other catalog, choose New & Info, from the left corner select catalog and prospects. you can now download the broadcast catalog Thank |
http://panasonic-broadcast.com/index...assID=66<br />
saves copying and pasting.. and thanks by the way :) |
Thanks Victor!
If I recall you can't download the DVX100A or DVC30 manuals from the Panasonic U.S. site. Everyone just needs to remember that while similar the manual links found here are for PAL models. |
Thanks. I will look through in detail but a first glance seems that line is not available. The manual still isn't up on either the the US or Canadian sites.
Ron Evans |
Ok, correction you can download a NTSC DVX100A manual by using this link.
I still couldn't find a NTSC DVC30 manual. |
You all are welcome, Sorry that the manual was not a NTSC DVC-30 version. Hope it will be up soon on the US and Canada site.
Bye good luck |
