dv953 color correction
I have 2 dv953s. I just bought one off ebay. The settings are exactly the same on both camcorders, exact same UV filters, but the colors are different. Is there any explanation that can help me. I bought the exact same camcorder to avoid this situation. Help please!!
Hello Derek and welcome aboard DVInfo.net!
Have you removed all the batteries (including the backup battery that stores the settings) and left them out for say an hour on both camera's? This should clear all and every setting (you may have missed some settings). Then the camera's should in theory produce the same signals, however I can imagine there may be slight differences between the camera's. How noticable is it after the procedure above? I assume these camera's are second hand? If so they may need calibration etc. (not sure if is possible to send to Panasonic and how expensive that would be). |
Derek, I know you've said the settings are identical on both cams but does that include the individual color and sharpness settings in Picture Adjustments under Advanced Functions in the menu (p.32 manual)?
You might also want to try adjusting the color setting even if they are the same to try and compensate for a possible manufacturing or component change (not necessarily a problem). |
color correction
I have not tried the color correction under advanced functions. I have been running the cameras in auto mode. Would that have something to do with it? I can try and run the cameras in manual and make those adjustments.
Forgive me if this was a stupid error, but I am just learning. Thanks |
Derek, thats a good question. I was under the impression that the color and sharpness settings effected the cam regardless of manual or auto mode. I could be mistaken since its been a couple of years since I've owned one. Its definitely worth a try and maybe a current DV953 owner can chime in.
Picture adjustment only works in manual. When you set it back to auto, the manual settings are overridden. That's true of the GS400 as well.
It will be good idea to reset the cams (there is dedicated small button on the side).
Then in Auto the cams can use different auto white balance depending on the source light direction and reflections. Use them in Manual mode set at the same settings for WB, or Manually set the white balance for both cams then check the results. |
