Audio Dub
Hey everyone--I'm trying to record audio from a cassette tape player into my DVX100 through the RCA jacks but am not having any luck. I'd like to record in 16bit on Channel 1 and 2 but couldn't find anything in the manual on how to do this. I see the audio dub button, tried pushing it in tandem with the Rec buttons adjacent to it but no luck. What am I doing wrong? Thanks!
Peter |
Check out function 50 on page 15 of the manual. Is your original recording 12 bit? I believe it has to be.
I think audio dub is for inserting extra audio (like narration) onto channels 3 and 4. 12bit= 4 channels of audio at 32khz sampling, 16bit= 2 channels of 48khz audio. If you're in 16bit you don't get the two extra channels and you get better quality (higher sampling rate).
I don't know how your camera works so you should probably check your manual (some online stores have them for download; bhphotovideo.com or henrys.com might work). |
Peter:
On you trying to dub audio under an existing video track? Or record only audio on a blank tape? |
Hi guys--I'm just trying to record only audio onto a blank tape, preferably 16bit on channels one and two. Thanks,
Peter |
Peter:
Don't audio dub, just record normally with lens cap on, cassette running into appropriate connectors (one where mic is currently in). Set to line level. |
Thanks Stephen--Does that mean record into the XLR's? Is there any way I can record into the RCA Jacks instead? Thanks,
Peter |
I think the RCA's are for 12-bit audio dubbing only but I'm not sure.
Thanks Stephen. So can I buy RCA to XLR converter cables, is there such a thing? And if I wanted to do the 12 bit audio dub, would I do that in VCR mode and use the audio dub button? Thanks again!
Peter |
Yeah, you can get convertors. Per the rest, you have to check the manual, but I think thats the way it works.
Surely you just have to put the camera in VCR mode and hit record... the camera will record audio through the XLR jacks when in camera mode, but it should record through the RCA jacks when in VCR mode...
That's what I would think too, Barry, but for some reason mine doesn't seem to be working that way. I will try to XLR method. Thanks guys,
Peter |
