DVC/DVX white balance at DVinfo.net
Old July 22nd, 2011, 07:51 AM   #1
When shooting with my DVC80 under a mix of fluorescent lighting and outside daylight, the white balance tends to cycle gradually through RGB values. It's very noticeable where there's a light-colored background or wall behind the subject. You see the color cast change when scrubbing the timeline. At the start of the clip, the background may look pinkish but 30 seconds later it could have a yellow tint. This isn't a consistent problem, but because I use aftermarket batteries I wonder if one of them isn't outputting steady voltage. Could this sort of thing happen with fluctuating voltage or would the camera just shut off?
Another thing I need to verify is if the WB shift occurs on manual setting or only with the 5600K preset. I am inclined to think it's happening with both because I favor those settings.
Have other DVX/DVC users noticed this WB shift? This is unacceptable for client work. Due to the camera's age and service hours logged, it's no longer cost-effective to have the camera serviced professionally by Panasonic. When I don't need HD, I love my DVC80. It's been a true workhorse that's paid for itself many times over. If it's time to retire it, so be it.
Freelance videographer/editor
www.tjborekvideo.com
Tim Borek is offline   Reply With Quote
Old July 23rd, 2011, 02:52 AM   #2
Re: DVC/DVX white balance
Hi Tim
I ran two of the PAL versions of the DVC20 here and I found a trick that seems to work pretty well and I still used it with my HMC72's and also my current HMC82's so the electronics can't have changed that much.
Leave the WB on auto and in the mixed light zoom into anything that's pure white (I do weddings so it's usually the brides dress of white table cloths). Watch thru the EVF and after around 30 seconds you will see the auto balance lock in a setting based on the white object. When the balance shows a definate change then simply zoom back to wide and you will find that the WB holds the setting you have "given it" and you shouldn't have much more problems...
It's something I discovered by accident and I have been using it for the last 5 years ..dunno how the auto WB holds the sample as if you have a manual WB, but it does!!!
The 80 should have the same electronics so try it...you just might be surprised!!!
BTW: When it's time to upgrade the HMC80 is an awesome camera if you don't mind going to shoulder mount cams....I love both mine!!! Otherwise it's the HMC150!!
Chris
Old September 23rd, 2011, 07:58 AM   #3
Problem was due to an old battery. No longer an issue.
