Blurry slow motion at DVinfo.net
Old July 1st, 2016, 09:54 AM   #1
Blurry slow motion
When using the slowmotion option on the DVX200 the footage gets blurred. I had it set at 25P FHD. Here are two stills images. With and without slowmotion. Have any of you here experienced this?
http://akfilm.is
Asvaldur Kristjansson is offline   Reply With Quote
Old July 2nd, 2016, 11:48 AM   #2
Re: Blurry slow motion
I don't have this camera so sorry if I'm not much help! What is the "Slow motion option" exactly?
I only ever shoot at a higher frame rate and slow down in post.
Also if you shoot 'slo-mo' at 25fps you're not going to get very good slo mo!
Nathan Buck is offline   Reply With Quote
Old July 4th, 2016, 08:23 AM   #3
The slowmotion option in DVX200 can be set up to 120 fps in full HD. I have set it to 75fps and by recording in 25p that is 3x slowing down.
http://akfilm.is
Old July 14th, 2016, 04:47 AM   #4
The full sensor's pixels are not being read out in 120fps mode. It's doing selective pixel readout with a lower quality debayering algorithm, hence why it's blurrier.
Of the effective pixels used, it only uses a fraction of it, hence why it can scan down the sensor so fast.
Jack Zhang is offline   Reply
