-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   Looks like wierd interlace artifacts (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/9368-looks-like-wierd-interlace-artifacts.html)
Kevin Merker May 6th, 2003 10:22 PM
I don't know what I am doing but I am getting what looks like interlace artifacts capturing 24p in Vegas 4 at 24p using the template in Project Properties
NTSC DV 24p (720x480, 23.976 fps)
720 X 480
none (progressive scan )
23.976 (IVTC Film)
0.9091 (NTSC DV)
Deinterlace method = NONE
Is there some thing I am missing or should do?
Kevin
Peter Jefferson May 8th, 2003 10:03 AM
are u using a PC monitor or external when viewing?
It could be your monitors interlacing...
Dennis Adams May 9th, 2003 01:34 PM
0) Do you have the 4.0b update?
1) Was the clip captured with the Sonic Foundry Video Capture program or something else? With scene detection on?
2) Does the clip show as 23.976 in the Media Pool (or Media Properties)?
3) Was the clip shot in 24p or 24p Advanced mode?
4) Does the interlaced frame show up every forth frame, or when?
Through the whole clip, or only part of it?
///d@
Peter Jefferson May 9th, 2003 10:30 PM
if ur not using 4b of vegas, it could be that.
I have notices alot of "flickering" and combing on the pc screen, but when monitoring on a television, it looks fine...
Hey dennis, i was just wondering, you know how in Vegas Capture u can set the default frame capture rate? Could this be an aspect of this type of distortion?
Dennis Adams May 9th, 2003 11:24 PM
Are you talking about the "custom frame rate" setting? That's just used for analog captures. The DVX100 (being a DV device) doesn't use that.
I need someone to send me a short clip and a project that exhibit this problem, because I can't get it to happen.
///d@
Peter Jefferson May 9th, 2003 11:29 PM
thanx for the response dennis,
much appreciated
Kevin Merker May 12th, 2003 10:28 PM
Interlace like artifacts
Hi Dennis.
To answor your questions.
Yes have Vegas 4.0b
Captured in 24p via Vegas 4.0b
Yes the clip shows 24p in both windows media an viewer 23.976.
Clip was shot in 24p. Use the preset but dropped to 1/24 shutter from 1/60.
NO I has artifacts at sporatic parts not like a set every 4 frames.
Where can I upload a source to you?
Kevin
Kevin Merker May 12th, 2003 10:29 PM
No scene detection was enabled!
Dennis Adams May 13th, 2003 06:37 AM
Re: No scene detection was enabled!
<<<-- Originally posted by Kevin Merker : No scene detection was enabled! -->>>
That's probably the problem. If there was a cadence break, the 24p inverse telecine would get off and produce bogus interlaced frames.
If this isn't the problem, drop me an email at dithermaster at hotmail * com and I'll shoot you an ftp address to upload a small clip.
///d@
Kevin Merker May 15th, 2003 10:44 PM
Dennis
After rereading your suggestions I realized that I was only looking at the interlaced artifacts on the computer monitor on rendered clips. The clips would play fine encoded mpeg2 using PowerDVD and would look interlaced using MS Media Player.
Most of all after reading what you wrote I realized that playing them back via firewire through my AG-DV2000 deck to my color Trinitron ntsc monitor all looked absolutly great. Man-o-man lots of days trying to fix something that wasn't broken. It had me pulling my hair out.
Again thanks ever so much!
Kevin
