Pan EVA-1 Question ? at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
4K and HD consumer camcorders with professional interest.
Old November 13th, 2017, 05:00 PM   #1
Greetings,
Did not see a Discussion page for my new Pan EVA-1 camera - hope this question passes muster - and someone can assist ?
Where and how does "one" set the recording format to (MOV LT or MOV HQ or even 1920X1080)?? Cannot find anything in the menu library ! Do you have to have a formatted SD card to activate recording format choices ?
Also - does anyone else find the actual included op - manual somewhat "light" on instructions ? Even the download op-manual seems "light."
Also - manual said initial camera "turn on" would be to set the "Region" -- my camera started with "Time Zone" setup, etc. I have checked Firmware Version on Pan site - and my version is the 1.05-00-0.00.
Appreciate any responses from members out there - thanks !
Russ Gutshall
Russ Gutshall is offline   Reply With Quote
Old November 14th, 2017, 11:59 AM   #2
Re: Pan EVA-1 Question ? Information Found
Greetings Again -- below is UK web info on Pan EVA1 -- a brochure which might assist anyone in US with some useful inf.
http://business.panasonic.co.uk/prof...1_Brochure.pdf
Russ Gutshall
Old December 26th, 2017, 12:27 AM   #3
I was the sound recordist last month on a short film shot with the first Panasonic EVA1 in the country.
Found even I as a sound recordist could easily navigate around the menus, everything is pretty easily set up in a logical way if I wanted to change anything (including yes even recording resolution/quality).
http://IronFilm.co.nz/Sound/ (Location Sound Recordist based in New Zealand)
http://www.YouTube.com/c/SoundSpeeding
David Peterson is offline   Reply
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic HC Series Camcorders
