February 28th, 2011, 03:59 PM | #91 |
Re: Moire with GH2 after converted
George, what can I say, fences are a big problem. You might have better luck with 24p High quality. But fences are always tough, especially chain link.
March 1st, 2011, 09:13 AM | #92 |
I agree, Brian. Using a pan of a fence as an example of poor performance by this camera is nonsensical UNLESS compared to another camera in the exact same situation for comparison purposes.
"The horror of what I saw on the timeline cannot be described." |
March 1st, 2011, 10:00 AM | #93 |
I posted to ask those here with experience of this camera if the patterning was something I should expect from this camera as I'd never heard mention of it during my research. The answer seemed to be yes in certain circumstances but not as bad as some other stills cameras that shoot video. That's interesting to know but wasn't really what I was after, I'm not doing a comparison or evaluation to decide which to buy. I had done that and had decided that this was the only stills camera that would suit my work practice. I tried it and didn't like the result, I might be quite alone in this but there you are.
I wasn't out to prove a point or criticise the camera, or say that there is a better one. |
March 1st, 2011, 10:22 AM | #94 |
If you will go shoot that fence with the GH2 set to EX TELE mode, you won't see any moire. It may not be as much fun as recreational equivocation on a forum but it will be an effective demonstration of the benefit of doing so. The GH2 is the only DSLR camera (with or without a mirror) that has a mode to eliminate moire in problematic shots - and you want to send it back for moire! That doesn't make any sense.
March 1st, 2011, 10:38 AM | #95 |
A good question might be, NOT which DSLR (with or without mirror), but which video camera can handle a chain link fence without some sort of artifacting. How high up the food chain does one have to go?
March 1st, 2011, 10:45 AM | #96 |
Once again: if it doesn't have a mirror then it's not a DSLR, by definition.
Sorry to keep harping on this, but the distinction is important. The GH2 is *not* a DSLR. If you want to assign a type to it then it should be called EVIL (Electronic Viewfinder Interchangeable Lens). Or if you don't like how that sounds, call it ILEV (Interchangeable Lens Electronic Viewfinder). But not a DSLR, which it cannot be, since it doesn't have a mirror. Hope this helps, |
March 1st, 2011, 10:45 AM | #97 |
Well George, you aren't the only one sending your camra back. Many are finding out this is not the camera for them.
I have friend who was totally sold until he used them for wedding work last week. They are too much work for many folks. The lenses required, the need for complete manual operations, the menus, are too much. When you put the effort into it, the results are stunning. Proof is everywhere. For ease of operation, compared to other similar, it is a walk in the park. For a traditional videographer, particularly those not experienced in manually operating a camera, it is a nightmare. I know, because I am a "traditional" videographer, with a smidgen of photography experience. Saturday was the toughest shoot of my life, and the results were extremely disappointing. The reason? I have not yet mastered the camera I own.
March 1st, 2011, 10:47 AM | #98 |
It would be a camera that has a 1 to 1 sensor array versus image size. Resizing in the camera causes moire. It's an unavoidable aspect of resizing. The benefit of the EX TELE mode in the GH2 is that it does a 1 to 1 sensor map. That's why it is able to shoots these difficult shots without moire. As they say in the commercial, "Try it, you will like it."
March 1st, 2011, 10:47 AM | #99 |
Sounds like it's better suited for controlled narratives rather than unrepeatable events.
March 1st, 2011, 10:52 AM | #100 |
It is an interesting feature, Jim. As Chris pointed out not useful for run and gun, but for run and gun moire is not an issue 99.999% of the time. Moire is not usually a problem when shooting speakers, wedding ceremonies, and the like.
March 1st, 2011, 10:56 AM | #101 |
Chris, Jeff - That's an excellent way to describe it.
March 1st, 2011, 11:08 AM | #102 |
George i have done several tests and find 720P resolution /sharpness to be the same as interlaced and i am not talking about after the 50i has been deinterlaced which loses resolution.
March 1st, 2011, 12:10 PM | #103 | |
Can you post a full resolution screen capture from your shoot, either in TIFF or PNG format. I am guessing that your Vimeo video clip is scaled down from the original size. Sometimes aliasing/moire problems can be introduced by the scaling process, so I am curious to see what a full resolution uncompressed image from your video looks like. |
March 1st, 2011, 09:03 PM | #104 |
George,
I don't know about CS5, but judging image quality on a timeline monitor wouldn't give an accurate representation of actual image quality with a lot of NLE's. Render it out and see if the problem is still there. |
March 2nd, 2011, 05:36 PM | #105 |
That is especially true when evaluating moire since resizing is done very much so on the time line and resizing is THE cause of moire.
