The Gh2 is light! at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX G / GF / GH / GX Series
4K and AVCHD on a Micro Four Thirds system camera with interchangeable lenses.
Old April 10th, 2011, 12:02 PM   #1
The Gh2 is light!
I shot my first wedding yesterday with my GH2. What a difference on a 12-hour long shoot. I normally use my EX1R as my primary camera at weddings mounted on a solid Libec tripod (read heavy!). What a difference the GH2 is. I used it on a lightweight Manfrotto tripod. It is so much easier to move around. I used the 14-140 mm. lens except for the dancing portion of the reception. I used the 20 mm f1.7 lens at 3200 ISO with one Pro light mounted high and dimmed at bit with a dimmer which worked out very well.
Love it!
Jim Snow is offline   Reply With Quote
Old April 10th, 2011, 12:48 PM   #2
Re: The Gh2 is light!
Yes, I'm going to all new tripod heads, my old ones are actually too big, IMO.
The horror of what I saw on the timeline cannot be described.
Old April 11th, 2011, 02:11 AM   #3
Which tripod do you use Jim and how do you find it?
I have the Libec DV22.
Brian
Old April 12th, 2011, 12:26 PM   #4
I bought a 701HDV Manfrotto head with 547BK legs. It comes as a kit from B&H Manfrotto 701HDV,547BK Video Tripod System Kit 701HDV,547BK B&H
A graphite or composite tripod would be even better but they are quite expensive. The one I bought is still quite lightweight and easy to handle. Whatever tripod you buy, I suggest you pick one with a ball head. It would be a problem without the ball for outdoor weddings for example where you often shoot on uneven ground. The ball makes it easy to adjust when you move around.
Old April 12th, 2011, 01:30 PM   #5
I bought my first 701 last week, and love it. Much more fitting than a 501hdv. I'm getting three more soon. I have big heavy tripod with a bar attached, and a 501hdv head and a 503 (all on one tripod) and when I replace the heads it will be much lighter. they just fit the weight of the camera so much better.
Old April 12th, 2011, 10:14 PM   #6
How is the panning? especially the beginning and end of a pan?
Old April 12th, 2011, 10:33 PM   #7
How funny, I just ordered that 701 kit from b&h just before i saw this thread. I mainly needed it cuz I ordered the Glidetrack SD and needed this style tripod to mount it on since my Davis & Sanford has a ballhead mount.
Patrick Janka is offline   Reply With Quote
Old April 12th, 2011, 10:41 PM   #8
Patrick you'll love it, good choice!
Old April 16th, 2011, 10:31 AM   #9
After you get used to the fact that it's smaller and lighter, it works fine. You need to use a lighter touch.
Old April 18th, 2011, 02:12 AM   #10
What the longest lens you've used successfully on it? I'm finding these inexpensive tripods like the Libec DV22 show their shortcoming with longer glass.
Btw, I rented a Manf. 504 and some fancy legs and hired a DP to shoot off it, he dialed all the drag out of the head so it was like panning on a ball bearing. Dunno if that's a common trick. I'd never do it.
Brian Luce is offline   Reply
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX G / GF / GH / GX Series
Google
1998-2018 The Digital Video Information Network
