November 22nd, 2011, 07:03 PM | #16 | |
Re: Still staying away from the hack? Shoot in low light?
November 22nd, 2011, 07:31 PM | #17 |
Yes. I just bought the camera 2 hour before I went to shot the wedding last Saturday. The raw you see in this clip is original from GH2 setting at 3200 ISO with 16MB/s. And I did hack my GH2 yesterday. Now it can record 44MB/s but not good for using Sandisk 32GB class 10 30MB/s (give you the message) and then I down to 35MB/s still using the same card, press record for over an hour. So far everything is perfect :)
November 25th, 2011, 03:23 PM | #18 | |
November 26th, 2011, 02:14 AM | #19 |
I am always quite happy to use ISO3200 on the GH2 as the high ISOs on the GH2 are remarkably free of noise but the shot needs to be properly exposed. If you use high ISOs & it is well lit with adequate aperture then it will look fine but if it is underexposed & you try to lift it in post then it will look terrible.
November 26th, 2011, 03:53 AM | #20 |
How would that work on shots using a slow telephoto like the 100-300 F4-5.6 ?
Could I push the ISO, shoot fast shutter and open up to 5.6 on the long end of the zoom I'm thinking surfing stills and video in bright morning light. |
December 3rd, 2011, 01:04 PM | #21 | |
I have to update what I said about the pulsing issue. I discovered that most of this goes away if you make sure that IR (intelligent resolution?) is off and sharpening is set to -2 in whatever film mode or preset you are using. With these appropriate settings, 24p from a hacked GH2 is beautiful. Nick Driftwood and the hack community have a nice showreel that may give you an idea what the GH2 can do: Pat |
December 6th, 2011, 12:21 PM | #22 |
Maybe I have really low standards or am just going blind in my old age. I played around a little with the hacks this weekend. I only experimented with the ones for AVCHD in 1080/60i since that is what I shoot in and don't care for the 24p.
I loaded the popular 42mbps hack for the 60i. I did a few tests shooting my computer screen with dark areas around it in low light. I could see no improvement with the 42mbs hack over the one I created to bump the 60i up to 24mbs. I tried the Driftwood SPANmyBITCHup settings as someone told me it was the cleanest that still spanned on long files properly. It was a pretty high bit rate and big file size. Didn't look any better to me than my basic 24mbps hack I made. The file sizes were about 3 times the 24mbps rate and I didn't see any improvement in handling low light artifacting. Maybe it would be visible in other types of shooting but for me the biggest thing I want is improvement in the quality of low light footage. For now the 24mbps in 60i is what I keep going back to and I still get 1.5 hours on a 16gb card. I did shoot some video at the 10K ISO with my 20mm/1.7 and overall it was acceptable if I was put in a situation where I needed it. I don't have access to NeatVideo but it was still decent compared to what I expected. My third GH2 arrives anytime now and along with it will be the 14mm/2.5 and the 45mm/1.8 lens. That should be good enough to be decent in low light for my work and only need about 1600-2000 ISO on bad shooting days. |
December 6th, 2011, 03:21 PM | #23 |
Phillip, if you need lowlight footage look at the 25mm F/1.4. It really is a huge upgrade over the 20mm f/1.7.
With the 12mm F/2.0, the 45 F/1.8 and the 25 F/2.0 your basically done shopping for lenses, minus your zoom lenses.
"The horror of what I saw on the timeline cannot be described." |
December 6th, 2011, 03:29 PM | #24 |
Philip -
What kind of scene were you shooting when you tested the hacks/higher bitrates? I haven't yet personally tried any of the hacks on my GH2. I'm waiting to see what the new official firmware that's been announced for December has to offer. (I hope it won't be much longer now.) But the type of scene matters highly when evaluating compression artifacts. A static scene, or one with an uncomplicated background won't generate much difference between frames, and therefore a low bitrate will be sufficient to capture all the detail. But highly complex, detailed scenes (leafy trees, for example) or fast motion, and especially both combined, use up all the available bandwidth digitally describing the changes between frames, causing all kinds of artifacts from blocking, loss of detail, uneven motion, etc. Its reducing those types of motion artifacts which attracts people to the hacks. People who primarily shoot interviews or static scenes probably won't notice or need the benefit of the hacks. Also keep in mind that each generation of compression/recompression introduces new artifacts. Going from AVCHD to ProRes, then exporting the final product as H264 or MPEG2 can reveal some of the weaknesses, although certainly the all-digital, nonlinear workflows we have today hold up far better than the generation losses suffered to projects for those of us who started in the 3/4" tape era. :-) |
December 6th, 2011, 03:35 PM | #25 |
Yea, that 25/1.4 looked real tempting when I was ordering everything but unfortunately my Canon A1 cams didn't quite sell for enough to allow me to spring for the extra money. I had to stay within those numbers. Now when I shoot a few jobs with the setup I have I may find I don't need that second 14-140 kit lens and could sell it and one of the primes I did get and get the 25/1.4. I know that 1.4 lens is sweet but I still have to ask people using them how they old focus. All my buddies shooting Canon's brag about their 50mm 1.4 lenses and how they can see in the dark with their 5D bodies. And I always ask how they hold focus if someone moves a step the wrong way. Just seems it would be tough to hold focus. Now granted we GH2 users are a little superior cause we have that nifty autofocus feature to help us along. :-).
For now I have the 20/1.7, 14/2.5 and the 45/1.8 plus the 14-42 and two 14-140 kit lenses. Add into that my old manual focus lenses with the adapters from my T2i and I also have a 28/2.8, a 58/2.0 and a 70-210/3.5. That's a pretty decent setup to run between 3 cams....but you are right that 25/1.4 would probably seal the deal. I just need a few jobs first to see how this arsenal works. I read alot of threads around here narrowing it down to that setup trying to get the most bang for my buck. For now I'm just going to enjoy the great footage I can get with what I have even if I have to bump the ISO to 1600 or 3200...it's sooooo much better than what I am used to seeing from my Canon A1 cams. |
December 6th, 2011, 04:00 PM | #26 | |
One challenge for me is I am not looking to fill up my 16gb cards real fast. The last hack I tried would have filled up my 16gb card in no time. So far I have found the 24mbps hack to be a nice compromise between quality and storage capacity. I may try the 32 mbps hack again outside in my yard one night and see what I get. That would be a better test. I was thinking for the weddings I shoot the 24 would be good for most stuff and if I needed to I could shoot 32 at the reception to help it out a little in quality. I could just setup FSH at 32 and FH at 24. Shoot at FH most of the day and flip to FSH when it gets dark. If the 32 is significantly improved I may go that route. Guess I need a better, more scientific test. Guess I wouldn't be good at Mythbusters.....just not enough science there. I have still not wrapped my brain around the whole Intra stuff and the settings. I know Intra is supposed to be better but everytime I try and grasp it I just get confused. :-( |
December 6th, 2011, 04:11 PM | #27 |
If you shoot weddings primarily, you'll ditch the 14-140mm pretty quick. I had mine maybe a week after the first time I used it, and then I couldn't sell it fast enough. Same with the 14-42, pretty much worthless for virtually all wedding work, except outdoors. I've gone through about a dozen lenses, and most all of them are long gone at this point.
December 6th, 2011, 07:38 PM | #28 |
Philip,
You probably already know this, but the bit rates in the hacks are often set lower for 60i than they are for 24p. So you might be looking at an even lower bit rate than you think. I have not liked the hacked 60i. I think the 24p really shows off the improvements offered by the higher bit rates and intra compression. Maybe the new firmware will give us 30p. Pat |
December 8th, 2011, 03:17 PM | #29 |
I would consider 24p if there was an overcrank mode to 48fps so I could do some slo motion. I don't do much as a rule but there are times I want to use it for a few clips and 24p sucks big ones for slo mo. That's the main reason I don't do 24p....plus I don't really care for the aesthetic of 24p on shots that have movement. That's my personal feeling but I know others really really love it. If I could overcrank it like you can in 720/60 I would consider it.
The new FW does have 30p at 24mbps wrapped in 60i. I've tried it out already and still prefer my hacked 24mbps setup I created in PTools but that's me and my tests were very unscientific. I may have to go run more tests. Yea, that means I can test and not work...always more fun that way. :-) |
