March 9th, 2012, 06:08 PM | #31 | |
Re: GH2 24p Cadence "judder"...
March 9th, 2012, 07:27 PM | #32 |
@Eric: I made sure that I was editing the video at 23.976 fps. Could this actually be my problem?? Should I be editing at an even 24p rather than 23.976?
Also, is vimeo converting my 24p stuff to 30p?!? And I am not sure I like the look of the 1/30 SS stuff... SB |
March 9th, 2012, 07:55 PM | #33 |
March 9th, 2012, 10:02 PM | #34 |
It's doubtful that any hack would help much with judder. Generally the hacks are dealing with bit rate increases that don't change the limitations of capturing movement with a limited number of frames per second.
1/30 shutter speed certainly would reduce judder as the image smear connects the frames better. It certainly makes the pan shots posted earlier smoother. However we start to enter a realm of issues caused by slow shutter speeds which start to translate to slower frame rates. Essentially frame rates slower than 18 frames impart a dreamlike quality to movement. 1/30 shutter speed works with modest subject motion but fast motion starts to look odd.
William Hohauser - New York City Producer/Edit/Camera/Animation |
March 9th, 2012, 10:21 PM | #35 | |
Code:
General Complete name : 37309808-hd.flv Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 2.31 MiB Duration : 7s 367ms Overall bit rate : 2 634 Kbps Encoded date : UTC 2012-02-22 14:08:24 Tagged date : UTC 2012-02-23 14:08:24 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 7s 367ms Bit rate mode : Variable Bit rate : 2 477 Kbps Maximum bit rate : 3 890 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.090 Stream size : 2.18 MiB (94%) Writing library : Vimeo Encoder Encoded date : UTC 2012-02-22 14:08:24 Tagged date : UTC 2012-02-22 14:08:24 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 7s 82ms Bit rate mode : Variable Bit rate : 157 Kbps Maximum bit rate : 180 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 136 KiB (6%) Encoded date : UTC 2012-02-22 14:08:24 Tagged date : UTC 2012-02-22 14:08:24 http://mediainfo.sourceforge.net/en |
March 10th, 2012, 05:18 AM | #36 |
March 12th, 2012, 07:11 AM | #37 |
Workflow aside. Just thought I would chime in and give you guys a link that shows some really good motion characteristics using 1/40 and a Orion hack for the gh2 that is optimized for the motion.
https://vimeo.com/35999739 The guy is really helpful and is a font of information. I think the motion looks as smooth as most of the high end cameras Ive seen. Maybe the hack can help some? |
March 12th, 2012, 10:32 PM | #38 |
Steve, I'll have to look into that hack and those settings some...
But since the last few posts have talked about workflow, I thought I'd chime in again with another video. This was shot at 24p at 1/50, edited at 23.976, and rendered at 23.976. https://vimeo.com/38299244 Let me know what you think, and if you still see some judder. SB |
March 12th, 2012, 11:18 PM | #39 |
Yes, I see the judder your talking about. I would look into the hack I mentioned for the smoother motion and see if that helps some. I usually try to avoid panning as much as possible or I do it really slow.
I remember when I used to export 1280x720 h.264 and upload to vimeo I would get color and motion issues. Someone told me to start using 1280x720 Windows Media Video file output 10k bitrate and I havent noticed anything weird going on anymore with colors either. I don't know if its due to the way vimeo handles re-compression or what but its worth looking into. Its all I use now and Ive been very happy. P.S. I am definitely no expert, just my experiences and talking to various people. |
March 13th, 2012, 12:50 AM | #40 |
Vimeo has converted your 23.976 fps .wmv file to a 30 fps .flv file. The original file does not have judder, but the streaming video has the same judder as before. I don't know why Vimeo is messing with the frame rate. Try uploading a .mp4 file instead.
March 13th, 2012, 01:52 AM | #41 |
I converted your .wmf file to .mp4 with ffmpeg
http://ffmpeg.org/ using the command Code:
ffmpeg -sameq -i 88459348.wmv -y 88459348.mp4 |
March 13th, 2012, 02:51 AM | #42 |
March 13th, 2012, 08:16 AM | #43 |
woops. I missed that you already were using a .wmv file. Anyway I am glad it worked out for you. I use TMPGENC, so I don't know how much is/if any difference with the various encoders.
Cheers! |
March 13th, 2012, 04:37 PM | #44 |
So I hacked my GH2 last night after reading the post above. I will do some tests and post again! Except this time I will upload an mp4 instead of a wmv.
Does anyone know if anybody else has had this 24p --> 30p problem with vimeoo?? SB |
March 15th, 2012, 01:39 PM | #45 |
Okay so here is a test with the Quantum v9b hack (the hack which was mentioned above).
Settings are the same as before, except I uploaded an mp4 file to vimeo instead of a wmv, thus (hopefully) preventing the 24p --> 30p conversion. Let me know what you think. SB |
