ninja 2 and GH2 - Page 2 at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX G / GF / GH / GX Series
4K and AVCHD on a Micro Four Thirds system camera with interchangeable lenses.
Old May 8th, 2012, 05:10 AM   #16
Re: ninja 2 and GH2
William - In my view, there aren't a lot of people doing this because they are making this 'return on investment' calculation: "Do I hack my camera to record to a costly external recorder - or do I hack my camera, record at high internal bitrates and get the same or better quality for a lot less money?"
For some people, who already have the external recorder, it might be worth it. But for most of us, the firmware hacks are much more practical.
And I think you do need a PC to run the AviSynth solution, unless you're a software wizard and can run it on a Mac using Wine and VirtualDub. Too complicated for me :-)
Cheers,
Bill
Bill Bruner is offline   Reply With Quote
Old May 8th, 2012, 06:46 AM   #17
Re: ninja 2 and GH2
The ability to record in the camera and an external recorder simultaneously would be great but as I am learning, probably not easily accomplished with the GH2. The cadence strangeness is easy to see on the 24p HDMI output just by panning the camera. The HDMI monitor I use accepts the signal without a problem so whatever is introducing the frame holds is prior to the final generation of the signal. The holds also don't seem to be regular but perhaps there is a pattern or a frame code generated that an enterprising programmer could elucidate and use in creating a ProRes file frame rate converter that I would gladly pay for. At this point I am going to test the free 44Mbit "Vanilla" hack and save $1000 plus dollars over the Atmos Ninja.
Old July 28th, 2012, 07:39 AM   #18
Re: ninja 2 and GH2
This may be true in the USA about Ninja, HDMI and GH2 problems - but how about Europe and PAL etc.? Any different here? Thanks, Hugh
Hugh Raggett is offline   Reply
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX G / GF / GH / GX Series
Google
1998-2019 The Digital Video Information Network
