More Reach
I own a GH2 with a Panasonic 100mm-300mm lens, which I understand equals a 200mm-600mm on the GH2. I also occasionally use the 2x function. Which gives me a total reach equivalently to 1,200mm.
Due to increasingly deteriorating poor health and mobility problems (MS) I am finding myself being more and more limited to main roads, or level short walks. What are my options for obtaining a telephoto reach equivalent to 2,000mm or more? Which long lens are available for the GH2 should I be looking at? What Combination of Lens & Adapters? any other options or suggestions? Thanks for your input and suggestions. David Rice Sitka Alaska |
Re: More Reach
500mm mirror lens recommendations: Micro Four Thirds Talk Forum: Digital Photography Review
That should have some options for you. To get past the 300mm range you need to get into mirror lenses. |
Re: More Reach
Rokinon 650-2600mm for Canon with an adapter might work. Not sure what mount versions are available.
Re: More Reach
David if you shoot in 720p60 and use the ETC mode on the GH2 you should get in the area of 2100mm with the 100to300 lens.
Gordon |
Re: More Reach
Maybe I should keep what I have, shoot 1080p and then just crop in post?
Any thoughts? |
Re: More Reach
If you use ETC and digital zoom I think you get around 1600mm on the 100-300.
I did a few tests with this a while back and I think you can also go to 4x plus ETC from memory. The magnification and quality was pretty amazing. |
Re: More Reach
I'm impressed with the quality of the ETC mode, but the video quality of the GH2 digital zoom is very poor.
Re: More Reach
While a slowish lens, I've enjoyed my Bigma - the Sigma 50-500/4.5-6.3. Incredibly useful tele range that I've used on everything from wildlife to lit stage performances, very smooth focus. I use a Nikon AF-D version with aperture ring. Used cost was about $700.
I've used this with a Nikon 2x teleconverter, but only in daylight. Only complaints are size/weight (but its a 50-500 zoom... What did I expect?) a bit soft at the longest end, and lack of ois, even with a tripod, can make the longest shots tricky. A sturdier tripod helps immensely. Below are two mini video samples with my GH2: |
