is GH4 LANC-compatible?
Hi there,
I've got a VariZoom VZRock LANC controller that I've been using with a Canon XF100. Does anyone on this forum know if this zoom-controller would work with a GH4? Thanks, Malcolm |
Re: is GH4 LANC-compatible?
Since nobody responded, I'll say this. Googling "GH4 LANC" will give you some answers. The B&H specs say it has a wired remote port. Panasonic historically refused to license the LANC protocol from Sony and had it's own. That's why there are some remotes that have special models for Panny camcorders. Eventually, BeBob built one that worked for both but the world went DSLR at around the same time.
Even if Panny did implement LANC, it would not zoom because, well, the GH4 has no zoom motor. There are some other functions in LANC like record stop and start and focus. YMMV |
When I asked a local dealer and GH4 enthusiast the same question his reply was what is Lanc? I went to another dealer.
The remote socket on the GH4 is the same size as the Lanc sockets I am used to. However I have been looking at pictures of various remotes for the GH4 and the plugs are equipped with a tip and three rings whereas the plugs on my two Lanc controllers both have the tip and two rings i.e. one less contact. So I would say that the GH4 does not have Lanc. The GH4 remote on the GH4 is only used for stopping and starting as well as single shots. Some of the third party remotes have timers for time- lapse functions. |
thanks Les and Alastair. Given that, even if I could find a LANC-style controller, I wouldn't be able to zoom in or out, I don't think it's worth it!
Regards, Malcolm |
Panny did implement LANC, but it's not LANC :), Panasonic uses different protocol, but all the options available with LANC for Sony and Canon, also available (depending on camera) on Panasonic cameras, including zoom :)) if you use PZ lenses, I just bought Libec lens controller and waiting for 14-42 PZ lens, it will be nice be able to zoom again on steadicam ! |
no. like others said it's a panasonic protocol. You need a remote made for panasonic , like the libec 3DV for example (switchable sony-canon/panasonic). Panasonic gives a 2.5mm port for zoom and a 3.5mm for iris on the video cameras. The libec will only control the zoom.
I have an old VariZoom controller and it does not work on the GH4.
I tried a manfrotto LANC unit. Only starts/stops video on my GH4. I don't have a servo zoom to test.
Does anyone know what features that are available through LANC in the GH4?
looks like the zoom works in the panny lenses
GH4 Crew » Blog Archiv » GH4 with 45-175 Power lens and Manfrotto remote |
