July 8th, 2014, 08:37 AM | #16 |
Re: GH4 Firmware v1.1 now Available!
Chad, where did you drag the .bin file to on your SD card? "DCIM", "MISC" or "private" ?
Ron |
July 8th, 2014, 10:32 AM | #17 |
I didn't put the .bin file in any of the 3 other items (folders) natively on the card after the GH4 formats it.
I simply dragged the .bin onto the SD card so that there were then 4 items on there, the .bin file and the other three that the GH4 creates after a format. You can try that, or the previous poster to this thread seems like he had luck deleting everything off the card and leaving only the .bin file on it before inserting back into the GH4. |
July 8th, 2014, 03:53 PM | #18 |
Just updated on a Mac with no problem. Download .zip, click it to open it it, drag that .bin file to SD card, camera updates, no brainer, this was the easiest firmware update I have ever done.
July 9th, 2014, 01:54 AM | #19 |
Well, got it to work but only after trying three SD cards. Transcend 64 gig Class 3, no go.SanDisk 16gig Class10, no go. SanDisk 32gig Class 10, bingo!
Ron |
July 9th, 2014, 11:18 AM | #20 |
Weird that for some of us, it works so simply and for others that it was picky about the card type/brand, file location, etc. When I first tried it, the camera wouldn't let me until I switched to a brand new, fully charged battery. Probably a good thing.
July 11th, 2014, 01:44 PM | #21 | |
SB EDIT: I actually got around to shooting a LOT of 4k footage yesterday, and even after the new firmware update, the camera still locked up, but only once. Wonder what's going on there... |
July 12th, 2014, 06:19 AM | #22 |
I have finally managed to install 1.1 in my GH4. I tried a new card and still got ‘no valid picture to play’. Next I deleted the first download from my computer and reloaded the update. This time it worked.
July 13th, 2014, 12:42 AM | #23 |
What card did you use? I experienced one lock up when I used one of my older 45mbs sec sandisc cards, I now have a Kingston 80/90mbs read/write card and the last 3 weddings it worked fine. I still have not updated to the new firmware though, will do that today.
July 15th, 2014, 09:27 AM | #24 | |
Speaking of which, I noticed last time it happened that I hadn't even pressed record yet. I had turned the camera on, and was manual focusing and getting all my settings right, and then when I went to press record, it wouldn't work. So I popped the battery, and then everything worked fine. Shot the rest of the day on it and it didn't ever freeze. SB |
July 15th, 2014, 09:35 AM | #25 | |
July 18th, 2014, 11:55 AM | #26 |
Thanks for the thoughts everyone.
Also, as a side note, my GH4 crashed again yesterday, but like I said, it was before I had shot anything, and I was just setting up the shot. I pressed the record button on the back and it didn't do anything, so I sighed, and took it off the tripod and popped the battery, and turned it back on. My grip looked at me and asked, "Did you just turn it off and back on again?" "Um, yes..." I stammered, slightly embarrassed. But it worked from then on! SB |
August 31st, 2014, 12:18 PM | #27 |
Hi, Juste went through all the angst and steps to update. for mac users
Here's what we found. Download the .zip file. double click to get to the .bin file. Heres the rub...You need the originally labeled bin file… if you download it more than once, as we did on successive attempts.. it will have numbers-1, -2 ,etc added to the label…(for ex: GH4__V11 5.bin) this "new" label will prohibit the camera from reading the .bin file… 1. Get the originally labelled bin.. (GH4_V11.Bin) by lopping off the additional space and number. 2. Format an SD card in the camera, put that card in your Mac. Drag all files on the formatted SD card to the trash and empty the trash. 3. Copy and paste the GH4_V11.Bin file onto the SD Card. - so it is the only file on the SD card. 4. put it in the camera and hit the Play button…. The onscreen upgrade menu ( Version Up) will come on..after a short wait.. It worked for us. |
September 4th, 2014, 12:41 PM | #28 |
That's how it will work. Had same problems and did that, and it worked after that.
Visit me and my work at www.artofduke.com |
September 13th, 2014, 11:33 PM | #29 |
I sidestepped all these issues by sending mine in to the McAllen service center for the "audio buzz" fix. They gave it quick turnaround (about 3 business days) and sent it back to me with ver. 1.1 installed. The audio is now clean and everything seems to work as it should.
To find out if your GH4 has the "audio buzz" problem plug in headphones, an external mic with switch OFF, set the input at MAXIMUM, and set the headphone level at Maximum. Carefully put on the headphones. At shutter speeds of up to 1/30 you will hear a staccato popping, at 1/60 and above it will be an obnoxious buzz. I usually use a separate audio recorder so almost considered not bothering with sending it in for the fix, but decided to anyway for when the day comes to consider selling it. Definitely gonna be harder with an audio problem. In order to get your GH4 repaired and returned to you as quickly as possible, the following information must accompany your GH4 when you send it to Panasonic’s service center: First and Last Name Physical Address (no PO Box) Telephone Number Email Address Description of the issue (e.g. “Audio buzz”) Send the camera only (no accessories) along with your owner information to Panasonic’s service center: Panasonic Factory Service Center GH4 AUDIO UPDATE 4900 George McVay Drive Suite B, Door 12 McAllen, TX 78503 Attention: Maria Alonzo Important: Ship your GH4 via a traceable insured shipper such as UPS or Fed-Ex to avoid any unforeseen delays in delivery. GH4's purchased new with firmware ver. 1.1 already have the modification and do not need the "fix". |
