GH4 Loses Sound at 24p @100mbps at DVinfo.net
Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX G / GF / GH / GX Series
4K and AVCHD on a Micro Four Thirds system camera with interchangeable lenses.
Old August 21st, 2014, 12:40 PM   #1
Hi All,
I'm in love with the GH4, but I had a huge headache at a wedding recently when sound appeared to disappear without warning. I was unable to find the fault until the following wedding, when I'd had sound working again for some time. Switching to 24p @ 100mbps, the sound fault appeared again, with the left and right channel icon disappearing and no sound being recorded.
I'm currently using v1.1 firmware. Completely bamboozled by this issue, as sound records perfectly in every other mode - so thankfully, I can get around it.
My question is: Does anybody have any ideas as to how to fix this? Heard any other users with a similar problem? Know what I should do next to rectify this problem?
Craig McKenna is offline   Reply With Quote
Old August 21st, 2014, 02:21 PM   #2
Re: GH4 Loses Sound at 24p @100mbps
Are you trying to do overcranking in 24p? If so, that will be the problem, as no sound is recorded in that mode.
Regards,
Bryce
Old August 21st, 2014, 02:43 PM   #3
Regards,
Bryce
Hi Bryce,
Can you please explain what overcranking is? I haven't tried to do anything (knowingly) except to record to that format.
Thanks for your input though!
Craig
Old August 21st, 2014, 08:13 PM   #4
HI Craig,
It's the variable frame rate you need to check. Go into the menu where you change the setting to 24p & just under that you will see the variable frame rate options. If this is on, no sound will be recorded. Turning variable frame rate off will get your sound back. Assuming of course that that's the problem. Good luck.
Old August 22nd, 2014, 03:46 AM   #5
HI Craig,
Thanks for this! I wish I knew that beforehand! :/
Can you explain why this occurs? I was unaware that this would happen, even after reading lots of information about going to 96fps...!
Such a relief that I don't need to do anything else to 'fix' the camera.
Old August 22nd, 2014, 10:12 AM   #6
Yes it's a bit of a bummer for sure. None of the cameras i've had that have done overcranking have recorded sound. Not sure any that do overcranking will record sound.
Is it the slow motion you are after? If not, & you simply want to record in 24p then you can simply turn off variable frame rate. You could always record in 60p & slow the footage down in post, that way you will keep your audio intact.
Bryce
Old August 22nd, 2014, 06:44 PM   #7
Bryce
I didn't realise that it was referred to as 'overcranking' - I just thought it was a strange way for the GH4 to reach its 96fps mode! Now I realise what it means and how it performs the task from the term... cheers!
I was after slow motion for some parts of the wedding, which is why I think I invoked the VFR during the preparation... I was planning to shoot 24p for most of the wedding, but using VFR to easily switch for the aisle walk etc. The way I saw it in my head was, that I could remain in that mode but just switch the VFR at times I preferred. Now I realise that it's best to stick with what I knew before - switch between the modes themselves, even if they can't do up to 96fps - 60p is enough!
I have always used the 60p mode (on the GH3) for slow motion... but I've always been unaware of this issue with overcranking... as I've never tried it before.
I've turned it off now, thanks! It's a massive help to know the cause and also to know that it's of no fault of the camera - just the user! ME! As usual! Haha.
Thanks Bryce... really helpful! Appreciate it!
Craig
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX G / GF / GH / GX Series
1998-2018 The Digital Video Information Network
