January 23rd, 2017, 07:21 AM | #106 |
Re: New Panasonic GH5 Official
The pdf presentation ( page 39 ) says LPCM recording to MOV only when XLR1 is attached, so no MP4 or AVCHD is my understanding from that. Audio will record to MOV and MP4 except at 100Mbps which is then AAC ( page 25 ). Looks like AVCHD does not have a LPCM option only Dolby AC3 or AAC.
January 23rd, 2017, 10:34 AM | #107 |
There must be a limitation on 96khz/24bit within the MOV only limitation... Might be troublesome for some NLEs like Magix Vegas which probably won't know what to do with a GH5 MOV until the software is patched.
I'm willing to bet you can't do 10bit 4:2:2 internal and 96khz/24bit PCM at the same time. |
January 23rd, 2017, 11:28 AM | #108 | |
January 23rd, 2017, 11:43 AM | #109 |
Ah, so you can't use 96khz/24bit over HDMI for 10bit 4:2:2 60p. In the very least they should allow 48khz/24bit for that mode.
In fact, I think the HDMI should in the very least do 2ch 48khz/24bit. |
January 23rd, 2017, 11:58 AM | #110 |
NO. You cannot do UHD 60P 10 bit 4:2:2 internally at all it is always 8 bit 4:2:0 internally. UHD 60P only available on HDMI in 10 bit 4:2:2 and then only if you do not record internally. Both these option do include the high resolution audio. You can have HD 1920 x 1080 60P 10bit 4:2:2 with high resolution audio internal after the summer firmware update. Either 100Mbps LongGOP or 200 Mbps All Intra. You should download the 86 page pdf as it has all the information. Embargo was lifted on 4 Jan. I think I got it from a thread on DVXuser forum.
January 23rd, 2017, 12:39 PM | #111 |
Yeah, that's what I meant, 96khz/24bit over HDMI in the HDMI only mode for the camera.
Now it's all up to the Shogun Inferno to support that over it's HDMI input. No SSD recorder on the market currently supports 96khz/24bit over HDMI. Edit: Just saw the PDF. It says (GH5 MOV only) for the 96khz/24bit mode on the XLR1. No indication whether that can be passed using HDMI in the HDMI only mode. Last edited by Jack Zhang; January 23rd, 2017 at 01:24 PM. |
January 23rd, 2017, 01:34 PM | #112 | |
January 23rd, 2017, 02:26 PM | #113 |
will be waiting for the new canon 6dii, love canons colours and the auto focus better than Panasonic especially the dual auto focus. nothing can beat the 70d/80d, so full frame with 4k coming will be sound, just saying thats my preference.
January 23rd, 2017, 07:37 PM | #114 |
I pre ordered a GH5 so when this turns up I'll let ya know about audio.
January 23rd, 2017, 10:05 PM | #115 |
With the exception of orchestral type classical music where more than one pieces of musical instruments are played for the recording I think 48 KHz, 16-bit LPCM would be fine. From my experience, the type of microphone, the placement, the quality of the preamp (either on board the camera or external) and not least the skill of the soundman in the more difficult shooting conditions, make so much more difference in sound than other factors. In most cases you can tell the differences in terms of audio characteristics/quality from those recording hardware by listening to carefully encoded MP3 files or AAC files (such as on YouTube) using adequate monitoring devices such as a good pair of headphones or carefully set up sound monitoring system with various speakers for anything more elaborate than a single mono or stereo tracks.
Just hope that optional XLR adapter comes with an adequate built in preamp that does at least on par with those built into their pro-level XLR camcorders. |
January 24th, 2017, 02:57 AM | #116 |
Thanks for that insight. However what makes you think the 6D mark ii will have full frame 4K when even the 5D Mark IV doesn't have this. Instead making a pigs breakfast out of its 4K implementation. Colours and auto focus are indeed Canons strength, which is alas the only good thing you can say about their video features in their DSLRS.
January 24th, 2017, 03:16 AM | #117 |
+ you can be sure Canon will cripple the camera in other video related area's to protect higher end models, like give it just enough moire, make the image softer or leave out functionality that is critical for video use. For video they have made clear that you need to get into their c-line of camera's to get everything you need.
Not only Canon does this, Panasonic also cripples anything below the GH5 just enough to make you want their flagship, like unusable audio on the gx85, no headphone in to monitor your sound on the g80 or make button integration or placement just awkward enough so it can become it bit frustrating. But that doesn't mean you can't do great things with these camera's, you just need to work around their limitations and get the best out of their strengths. For the canon that will be autofocus and color and for panasonic ibis and the small formfactor. |
January 24th, 2017, 06:04 AM | #118 |
I also like Canon's video image but to be realistic the best you can hope for on the next 6DII or whatever is maybe a flipout screen which is a defining feature of most Canon's lower end DSLRs to facilitate video shooting. Other than that it can't do better than the 5DIV that traditionally has always sat one level up above the 6Dx in price and performance.
Panasonic has a simpler job with the GH5. They can go full tilt with it within the limitation of sensor size and form factor because there is no longer anything like the dead AF100 class of cameras to protect. Other things they are offering in 4K are geared towards different, and mostly higher end types of video shooters. |
January 24th, 2017, 10:11 AM | #119 |
The new 6dii is heavily reported to be having 4k but if it comes great if not i will still get it, flip out screen, dual auto focus, touch screen. full frame, that will do me just fine.
January 24th, 2017, 10:52 AM | #120 | |
Of course, not saying the new 6D Mark II won't meet your needs. Just that my own list 10 bit 4:2:2 recording, 4K at 50p, 5 axis stabilisation for smooth hand held shooting, Log Profiles, focus peaking, highlights monitoring, dual card slot, and non cropped 4K so that I get the full field of view from my best lenses. Yep whilst pretty demanding of me, the above will definitely do me just fine. :) Last edited by Steve Burkett; January 24th, 2017 at 12:57 PM. |
