Panasonic GH5 firmware requests
Ok, I’ve had the GH5 for a few days now and things I would love in a firmware update.
When in movie mode and using either A, or S I would like to see the values of what either one is doing when using the camera in semi auto for these modes. Also when using auto ISO I would also like to see what value this is at when in auto ISO. Also the above when combined with using AE lock I would like to see the auto values rather than not knowing what values these are at. Why, well if I use the GH5 in movie mode S and then let the camera ramp the f stop up and down and I don’t really want my f stop to get any higher than f8 on some lenses due to the image becoming soft at higher f stops, like wise I might not want f2.8 I might want f4 etc… I could then make a change by adding a ND filter etc... Sony implemented this and I loved this feature when using small cameras, it's just easier for me. |
Re: Panasonic gh5 tutorials
Absolutely agree. I will use the GH5 unattended controlled by the WiFi app and there are a few more things I would like in addition to knowing what the parameters are whether in manual or auto. I get peaking when in pause but it goes away on the app when in record...Why ? As it is still there on the camera. Like you I want the camera in semi auto but will intervene if I think it is going outside the range I want it to be in. I am used to seeing this on almost all my Sony camcorders and would like the GH5 to operate in the same way. Show the parameter with a little A beside it when in auto for example. Likewise I like a function to stay on when I switch it on ( peaking ) whatever the mode until I switch it off.
I wonder how one goes about requesting firmware Ideas to Panasonic, any know? could be worth a shot.
I would make a separate thread called "panasonic gh5 firmware requests" and post your requests there, this thread however I would only use to post tutorials, tip and tricks or anything that would help to better understand how the the GH5 works.
I took Noa's advice and have split these posts -- separate topic, separate discussion thread -- and pinned to the top as well.
Re: Panasonic GH5 firmware requests
Thank you Chris.
Great Idea Noa and thanks Chris.
Cheers, S |
Here is one for Panasonic: give the opportunity to magnify the screen for critical focusing WHILE the camera is recording. Now it only works when the camera is in standby.
Another function which should be available I think.
When in auto ISO and in manual A/S in movie mode I would like the camera to tell me where I am in regards to exposure am I under or over exposed. |
Hi
Regards Phil |
Yep that's correct about shooting in S mode and I also under expose using AE shift by a 3rd, however there is still no reference if the shot is over or under exposed other than looking at the scene, oh you could use zebras although I tend not to anymore on these small cameras.
What I have noticed is shooting photo mode using S one can see the auto values, I discovered this late last night and will explore more today and do a comparison against move mode v photo mode shooting a movie. |
Ok, If are like me and want to know what's going on when you are in S mode with ISO, and f stop in movie mode you can't in this mode mode. You have to be in photo mode and select S which I like to keep my shutter the same (PAL 50) If you depress the shutter slightly you'll see the f stop and ISO settings however they will disappear in a few seconds. I also use the AE lock engaged (turned on) in the menu and the hit the AF/AE Lock button on the back and this will hold those settings.
Adding one more gotcha ya, when you press the record button all this info disappears, so It's only useful when setting up a scene. Panasonic, can you please make this possible in video mode please and keep the info in view while recording. Cheers, Simon Oh also while your in photo S mode you can also use the AE shift which I use and under expose by a 3rd, this I have carried over from my Sony A7 cameras. |
Hi
I might be wrong on this, however I thought whatever photo mode we are in, if a video recording is triggered the exposure is always fully automatic, so shutter/aperture will be changing. Just because the shutter is set as 1/100th in photo mode doesn't mean it's set as that when a video is started. Only when selecting the Video mode option and selecting S from the video menu do we get to fix the shutter speed (or aperture etc). I think the exposure settings you are seeing on half shutter press when in photo mode are just those applied to the picture if taken. Regards Phil |
Yes Phil, that is my understanding too. So if you want control in video mode you have to be in creative video on the dial. The mode then is set in the menu. When in this mode and shutter priority the WiFi app does show the iris value but not ISO/Gain if set to auto gain. PC transfer application will show what the values were as they are in the file.
