July 1st, 2018, 02:39 AM | #16 |
Re: Variable ND Filter Quality? Need help to decide.
I didn't even knew lens hoods existed that go on to the front of the nd filter but I just found this which might be what Adriano is looking for?
July 1st, 2018, 02:47 AM | #17 |
Yes, I liked that video even if I don't like to add adapter rings for the filter.
A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos |
July 1st, 2018, 09:53 AM | #18 | |
Yes...its limited to 6 stops which, I guess, is why its quality is high. Im OK with warmer color cast as im color grading in post anyway. My biggest fear was losing resolution as that is something that you cant recover or correct in post. So, no X pattern and maintains resolving power. Color shift is an easy fix for me. I always warm or cool my stuff anyway. CT |
July 1st, 2018, 11:03 AM | #19 |
Reducing temperature in camera or in post is digitally raising the blue channel from its native temperature at 5600k. This will increase blue noise in the shadow. Cooling filters or lighting are preferable.
Unless you are really after the look caused by colour shift and no intention of correcting it then this should be considered a negative side effect. |
July 1st, 2018, 12:33 PM | #20 |
This is an older comparison but I am sure it still stands good.
A little knowledge goes a long way but not long enough. |
July 1st, 2018, 01:37 PM | #21 | |
However, this doesnt stop Hollywood or anybody else from lifting, twisting, bending, saturating and stretching the Hell out their videos. I often use six vector editing in post to push colors I want to stand out or suppress ones I dont. How many people do a rigid "what you see is what you get" work flow? I'd bet that a huge portion of your favorite looking videos/movies were corrected and color graded (often quote a bit) in post. They almost never looked exactly that way right out of the camera. This is an incerdably normal thing to do.....especially with a 10bit GH5 |
July 2nd, 2018, 12:26 AM | #22 |
I read SLR Magic gives a problem in the center of the image (dark halo) when you rotate it to the maximum, then it has only 4 stops. I'm considering whether to buy this SLR Magic or B&W BW1075251
You know I'm going to Africa ..... in your opinion, which is better to buy between them? This is the link of B&W filter: https://www.amazon.it/BW1075251-Neut.../dp/B00GRQE0ES
July 2nd, 2018, 01:24 AM | #23 |
I can only speak for my copy. I'm a pixel peeping fool and I have gone over mine pretty obsessively and I'm verry happy with how it looks. I also have a Tiffen variable ND which is OK but I like the SLR Magic better.
Your milage may vary. CT |
July 4th, 2018, 01:08 AM | #24 |
If you should choose between the two options, would you shoot "like 709" or "Standard"?
A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos Last edited by Adriano Moroni; July 4th, 2018 at 11:51 PM. |
July 9th, 2018, 03:32 AM | #25 |
What could it happen if I shoot 50p 8bit and I make video editing at 25p?
Will my documentary look like as it was shot at 25p? Thanks.
July 9th, 2018, 07:25 AM | #26 |
No, it will look "different." You need to test this yourself, both with relatively still and moving subject/camera. Then you can describe to yourself what you see - by far the best way to learn the difference.
July 9th, 2018, 11:43 AM | #27 |
I accidentally did a test with the GH5 with the "Hybrid Log Gamma" profile. It's a very flat and faded profile that seems like vlog. Then I added the "Primary Color Correction" filter to the clip on Edius Timeline clip and the miracle appeared as if by magic. I got a very good, almost excellent image in a tenth of a second. Of course, then you can change the color as you wish on that image obtained. Have you ever made this test? Is it convenient to shoot with that profile? I could never imagine that I could get that quality with just one mouse move. I also tried to add "Primary Color Correction" to other clips I shot with other profiles, but nothing happened. They don't even see that filter. That filfer seems to have been procreated for the "Hybrid Log Gamma" profile.What do you think about it?
July 9th, 2018, 01:21 PM | #28 | |
If not experienced in shooting LOG, I would not advise you to do so. If you want to learn more about LOG, go shoot a bunch of LOG footage under different lighting situations, and research it yourself online - google, bing,etc. are all your friends. |
July 9th, 2018, 02:24 PM | #29 | |
You can check this by looking in the pcc window and look at the tab colorspace, normally it says that under source: auto (bt.709) and under destination lut: project color space (bt.709) and base says "display light. Compare that to the properties in your clip and probably you have got a other values that edius assigns automatically. |
July 9th, 2018, 03:20 PM | #30 |
In your opinion is it possible to get better results shooting "Hybrid Log Gamma" profile and to apply that LUT in post or shooting "Natural" and adjusting a bit the colors in post?
