Go Back   DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX GF / GH / LX Series
4K and AVCHD on a Micro Four Thirds system camera.
Old February 24th, 2011, 08:15 AM   #1
Videomic Pro for GH1/GH2
I'm probably the last one to find out about this microphone, but I wanted to share this information with anyone that needs a shotgun mic for the GH2, or any DSLR type cam. I ordered mine yesterday, and I'm excited about the small form factor and the more attractive/efficient mounting system.
Rode VideoMic Pro
at B&H:
Rode VideoMic Pro Compact Shotgun Microphone VIDEOMIC PRO B&H
Rode site:
RØDE Microphones - VideoMic Pro
http://JeffHarperVideo.com
The horror of what I saw on the timeline cannot be described.
Old February 24th, 2011, 10:30 AM   #2
Re: Videomic Pro for GH1/GH2
You will need an adaptor going from the 3.5mm Output Plug to the GH2 .2.5 mm jack.
Jim Forrest is offline   Reply With Quote
Old February 24th, 2011, 10:40 AM   #3
Thanks for the heads up Jim. I got one from Radio Shack for $3.99. Not good quality, but should work for now.
Old February 24th, 2011, 03:08 PM   #4
I run the new Video Mic Pro on my GH2.
The radioshack adapter will not work - actually it will give you mono - one right or left track but not both.
You will need a stereo 3.5 to 2.5 adapter - Hosa for example, is the most popular.
Hosa Technology GMP-467 - Right Angle Adapter GMP-467 B&H Photo
Jon Braeley is offline   Reply With Quote
Old February 24th, 2011, 03:27 PM   #5
Jon, that is VERY important information, thank you. I'm on the hunt for one now.
Old February 24th, 2011, 04:00 PM   #6
Jon, my adapter is working fine with my videomic, perfect, both channels. Are you still pretty certain it won't work with the pro? I'm hoping it requires the same plug as my videomic. My newer mic arrives tomorrow, and if it doesn't work there is a local audio house that will likely have something I can use.
Old February 24th, 2011, 07:13 PM   #7
This is what I purchased and it works great.
Sennheiser MKE 400
Sennheiser USA - Camera Microphone - Camcorder Microphone - MKE 400 - Directional shot gun Microphone - Professional Audio
After buying a 3.5 to 2.5 adapter at Radio Shack, of course. I also made a short wire adapter using a right angle 2.5 plug I found at Radio Shack but that was a soldering nightmare. It works however.
Edit/Camera/DCP production/Animation
Old February 24th, 2011, 08:38 PM   #8
William, if you're interested, here's a video of a comparison of the older videomic, and your Sennheiser, along with a Sony tossed in. You may have already seen/heard it. The little Sony was surprisingly good for it's size, but of course it was at close range, which gave it a bit of help, as from a distance it would be relatively poor compared to the other two, I'm guessing.
Field video mic: Rode VideoMic vs. Sennheiser MKE 400?
I had looked into the Sennheiser, but I already had a videomic, and was pleased with it. The newer Rode Videomic pro is supposedly improved over the original, and is much smaller, so I went with it.
Your Sennheiser is extremely popular also, and it well liked for it's small form factor, which came along before the Videomic Pro, so I can see why you chose it. It does seem to be a little light on the lower end, but otherwise seems pretty good. But is is pricey!
Old February 25th, 2011, 05:55 AM   #9
I tried a 3.5 to 2.5 adapter from radioshack and could not get stereo both tracks to record. I was then told this adapter is for cellphones only and mono. Now it may be that radioshack sell more than one type of adapter and do sell a stereo version.
However, for $3.50 it is not a big deal to order one that you know is stereo.
Old February 25th, 2011, 07:00 AM   #10
Jon, I still appreciate your attempt to warn me, details like that can be crucial.
Old February 25th, 2011, 08:38 AM   #11
Videomic Pro arrived, very nice
The original Videomic was good, but had a couple of issues. When moving the camera, it tended to make noises that would end up on the video. I just didn't like the way it flopped around.
Also it tended to be a bit on the noisy side, but for $140, the quality was unbeatable. I don't know of any in that price range that were as good.
The Videomic Pro, on the other hand is perfect, absolutely quiet, much improved, with a +20 setting that I will find very useful.
It is a slick little piece of equipment, superb sound, super small, looks very nice on the camera.
On the other hand, it feels very delicate to handle, which I don't care for, but overall it is very nice.
It is more sensitive as well, I might add. Lastly, they are sending a deadcat for registering on their website, which is a super nice deal.
Old February 25th, 2011, 09:59 AM   #12
I use the Senn ME66, which has it's own 48v power, I've always wondered if these Rodes work on a fishpole. It looks like they're built exclusively for a hot shoe mount. That'd be a major limitation.
Old February 25th, 2011, 11:20 AM   #13
The only reason I went with the Sennheiser was the forward bulk of the Rode mike which would have intruded on the wide angle shots on another small form HD camera (JVC) I use the Sennheiser with also. On the GH2 I'm not sure that would be a problem as the mike is mounted higher from the lens.
The low ends are very good for me. In fact the GH2 records more of the low-ends than my other small HD camera.
The Sennheiser can be purchased for quite a bit cheaper than the MSRP on Sennheiser's web site. That said I would have gone with the Rode if I had purchased the GH2 first.
Old February 25th, 2011, 11:26 AM   #14
At any rate they are both fine mics, and I'm just happy to have a smaller mic, my older Rode was much too large of a contraption for the tiny GH2.
Old February 26th, 2011, 09:47 AM   #15
Brian, Rode has a full line of accesories for their mics, including cables, boom poles, etc.
Omega Broadcast
(512) 251-7778
Austin, TX
Z.G.C.
(973) 335-4460
Mountain Lakes, NJ
Abel Cine Tech
(888) 700-4416
N.Y. NY & L.A. CA
EVS
(800) 238-8480
Glendale, CA
Precision Camera
(800) 677-1023
Austin, TX
  You are here: DV Info Net > Panasonic P2HD / AVCCAM / AVCHD / DV Camera Systems > Panasonic LUMIX GF / GH / LX Series
Google
1998-2015 The Digital Video Information Network
