Setting a specific F stop with an adapter at DVinfo.net
Old August 30th, 2012, 07:22 AM   #1
I have Rainbowimaging Canon EOS EF Lens to Micro 4/3 Camera Mount Adapter and would like to know how to avoid the wide open lens when I using a Canon mount lens with my GH2.
I mean, what`s the procedure to set a specific F stop in the (EF) lens to work with this cheap adapter - aware that it won`t change while working with GH2?
Ron German is offline   Reply With Quote
Old August 30th, 2012, 11:13 AM   #2
Re: Setting a specific F stop with an adapter
Ron, I believe you need to change the iris using a Canon camera, than place the lens on your adapter and put it on the GH2. I think.
Old August 30th, 2012, 11:32 AM   #3
Thank you Jeff, but there is a way to change the iris with a Canon camera AND KEEP IT when put the lens + adapter on the GH2.
That`s what I need to know.
Old August 30th, 2012, 11:40 AM   #4
You have to hold down the DOF preview button on the Canon camera body WHILE removing the lens. That should do it.
http://www.LandYachtMedia.com
Old August 31st, 2012, 06:26 AM   #5
Thank you Chris.
Just to confirm: with the camera (Canon) turned off ? (You have to hold down the DOF preview button on the Canon camera body WHILE removing the lens)
Old August 31st, 2012, 06:35 AM   #6
You have to do it with the camera turned on. It won't work if the camera is powered down.
When you press (and hold) the button you will hear the iris move. That is when you remove the lens. Be sure to keep holding down the DOF preview button.
Old August 31st, 2012, 11:53 AM   #7
Thank you again Chris.
Regards
