Re: Panasonic LX100 - 4K Video M43 Compact
The color is also very nicely balanced and better than I was ever able to achieve in my GH4. But yes, you are correct, video is always easier and less 'stressful' for the camera on cloudy days. |
No sun until Thursday here. I may be able to sneak in some video then. This is gopro weather!
-- peer |
I was not aware about this either until a few weeks back, I couldn't understand why some users with the same camera as I had managed to get so detailed uploads on vimeo until someone pointed me to that 1080p upgrade option and suddenly my uploads became much crisper and clearer. I think many users don't know about this either which is why people see difference in detail because some are 720p and others 1080p converted.
I always upload the 4K version, and anyone who joins Vimeo can download the 4K original (not ooc original of course). If someone really wants to judge video quality it seems strange to look only at the highly re-compressed streaming version, even if it's 1080 (mine stream at 1080).
But yes, I know about the uploading process with the manual selection of upgrading to 1080p. |
What is the recording limit on this or does in not have one? |
Michael,
15 mins in 4K mode…but there is a possibility (I have yet to see hard evidence) that the Leica badged variant (which I believe will have a different firmware and is only very slightly less of a bargain, price wise) MIGHT have a 29 minute limit…Let's hope so! |
Here that Leica is over 20% more expensive, about that recording limit, are you sure it's 15 minutes? On the panasonic spec sheet I see that continuous recording time is approx. 90 min (4K/25p) and approx. 120 min (FHD/50p) but then again the actual recording time is half that so I don't understand what they are referring to.
Re: Panasonic LX100 - 4K Video M43 Compacted
Noa,
On the Panasonic spec sheet there is a note (one of many at the bottom) that lists the 15 minute limit in 4K mode. On the Leica spec sheet there is, currently, no note (just the up to 29 minutes listed in the spec). Time will tell if the lack of a qualifying note regarding a 4K time limit of 15 mins is an omission....or not. I suspect both cams might be the same but let's wait and see - if the Leica does have a different firmware we might just get lucky! |
Ah the fine print...:) I guess they are trying to guarantee you get 15 minutes of recording time no matter what instead of risking that the camera shuts down mid recording due to overheating.
It seems that given sensor/lens combination, it does not allow for much shallow DOF, unless you are very close to the subject? Otherwise is mostly an 'everything in focus' look?
At f1.7 when wide open you can get a narrower shallow dof with obects that are closer to you then with any other comparable pocket(able)camera out there but as soon as that distance increases you'd get more front to back sharpness, for lenses this wide the only other option would be to get a full frame camera and a fast 24mm lens prime but then you don't have a pocketcamera anymore.
