P2 Import hanging at 4.7GB on FCP
Hi guys,
I am attempting to import some P2 footage into Final Cut (6.0.6) and the import keeps hanging at 4.7GB. I have tried different clips, different cards, transferred the card data to the drive and attempted to import, and used the P2CMS utility, still no luck. The drive is aa G-Raid that is formatted as Mac OS Extended, but is not journalled. I have a couple drives that are not journalled and haven't had this problem. Any guesses as to what is going on? Thanks! Peter |
Hi Peter I had this occur on one clip last night and found that my drive was formatted as MS-dos. I reformatted in mac extended and it was OK but as you say this is what you already have done.
Have you tried re-formatting the drive or is this impactical it may be that the directory is corrupted and needs initialising. |
Hi Gary,
Yes, it would probably not be practical for me to reformat the drive. What's really strange is I just shot some new footage onto a different card and was able to import it no problem, so perhaps something is wrong with these two cards? But I was able to import the footage from them using a different computer, so that doesn't hold true, either. Very strange. Peter |
Peter,
Just saw this on a report about Apple upgrading Leopard "Resolves an issue that could prevent importing of large photo and movie files from digital cameras" Wonder if P2 got caught in the crossfire. If you are using Leopard on Mac Try installing the latest upgrade to system software. Maybe this will help |
Thanks Daniel. I just upgraded, so we'll see if that helps.
I had the problem again (before upgrading) with some stuff I just shot, so I tried moving the P2 card reader from FW over to USB and it worked fine. I had it hooked up in a FW daisy-chain (it was 6th in line) so I'm wondering if that was part of the problem. Peter |
Peter, what P2 card reader are you using then?
Also, if the G-Raid is near-full this could also be the problem as the transfer process requires a certain amount of free-space to "pre-allocate" during the transfer. If the read-ahead information tells the system that it's lacking free space to continue the transfer it will stop in it's tracks. Lastly, the G-Raid series has been hit-and-miss with communication reliability; you might want to see if there is any firmware updates from G-Tech that address communication for the chipset. If none of that helps let us know. |
Thanks Robert. By switching from FW800 to USB I was able to import no problem, so this would seem to rule out a problem with a directory on the drive. The drive has about 1.3TB's of space, so that is not an issue, either. My only guess is that by having the P2 card reader (AJ-PCD20) at the end of a 5-drive FW daisy-chain, this somehow created an issue for importing. But that is just a guess.
Peter |
That could very well be; the P2 card reader on the PC is often installed inside the tower case and gets it's own dedicated FW channel (on certain mainboards) however on the Mac all the FW ports share the same channel which is why it would be a good idea to get a PCI-e FW card and create your own channel separation for the HDD's and the P2 reader.
If you're on a laptop that's a different topology but there's still other methods for getting discrete FW channels for input. |
