Anyone have any info on the VariZoom VZ-TFT7 7" on HVX camera monitor?
Anyone have any info on the VariZoom VZ-TFT7 7" on camera monitor? I know the Marshall R70P HDA monitor is the best, but at $1500 it is out of my price range. I have to cut some corners equipment wise or I'll never have enough money left for cast and crew for "Holy War".
I just sent this question below to VariZoom and I'm waiting for an answer, but they might be a little too pro on their own product so I thought I'd check in here and see if anyone here has any experience with this monitor. Here is a link to it. http://varizoom.com/products/monitors/vztft7u.html I'm looking at a couple of your VZ-TFT7 7" on camera monitors for my 2 Panasonic HVX200's. I'm in the process of filming an indie flick and plan to shoot in 720-24p-pn. The resolution is 1440X240 / 480X240 lines according to their spec sheet. I'm not all that knowledgeable when it comes to some of the specs so I was wondering if the resolution is good enough to use for focus in 720 HD. This looks like a great unit for me, but it would have to have enough resolution to be useful for focusing my cameras. Thanks. David M Payne |
It is a standard definition monitor with 240 vertical lines of resolution. It will make a good framing monitor. I'm not sure if any standard definition LCD monitor is adequate for checking focus though.
I'd echo that the Varizoom or any other low res TFT would only work for framing and viewing generally from afar for reference and for crew/talent/etc to see the image. In terms of focus, you'll be needing to use the HVX200 LCD with EVF DTL and/or Focus Assist, or a higher res external monitor. At first I was feeling lost with the stock LCD. But after a few weeks of using EVF DTL, I'm confident focusing using the HVX LCD.
My guess is they could get it under $1000, they would sell as many as they could make. Almost every 1/3" HDV/HD owner gripes about camera LCD/Viewfinder rez. |
David,
I would be a bit leery about VeriZoom monitors. I bought one a while ago and it was very flimsy, lo-rez... the 1/4-20 mount FELL OFF after a while. I don't know if they've gotten better-- they look like they have, but that is my experience. If you can check it out in person before you buy, you'll likely thank yourself. As for that Marshall, are you guys using it just for focus or as a reference monitor as well? I'd feel a bit naked without a CRT ref on set... |
Thanks for the tip. Here is a bit of info and the links to these two 7" and 8" models.
This 7" looks good at $349. XENARC 700Y™ / 700YV™ 7" TFT LCD Monitor with VGA and Optional AV inputs about 1.28 Lbs. NTSC / PAL Multi-System (700YV) 16x9 Aspect Ratio High Resolution Display - up to 1600 x 1200 http://www.xenarc.com/product/700y.html Now Available in Silver or Black! Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 7" LCD screen with VGA input. In-Car computing is the next step in computing technology, and we are committed to serving this up and coming technology sector. Don't mistake this monitor for an ordinary video monitor that displays composite video. This 7" monitor has 800 x 480 pixels (2400 x 480 sub-pixels) that help display crystal clear texts and ultra-sharp images through your computer's VGA signal. These monitors come included with an instruction manual, a monitor stand, an AC adaptor, a connection cable, and a cigarette lighter car adaptor. But this one might be even better, except for the weight. XENARC 800YV™ 8" TFT LCD Monitor with VGA and AV inputs at $449.00 about 3Lbs. http://www.xenarcdirect.com/store/pr...250&bestseller Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 8" LCD screen with VGA input. In-Car computing is the next step in computing technology, and we are committed to serving this up and coming technology sector. Don't mistake this monitor for an ordinary video monitor that displays composite video. This 8" monitor has 640 x 480 pixels (1920 x 480 sub-pixels) that help display crystal clear texts and ultra-sharp images through your computer's VGA signal. The brushed, anodized aluminum face plate gives the monitor a futuristic yet elegant look. The entire enclosure is constructed with aluminum, making the unit both strong and light weight. This monitor comes included with an instruction manual, a copper monitor stand, a U-Shape Mount, an AC adaptor, a connection cable, and a cigarette lighter car adaptor. Thoughts on these two? David |
I'd like to know how those work out with the HVX200. Post back if you buy one and try it out. |
Monitor Options
Hey Guys,
Thanks all for the heads-up about the Varizoom 7"; I actually did buy one last week to compliment my EZFX jib. I didn't realize until reading this thread that the rez on the Varizoom was so low. I also bought the Varizoom HVX remote (Rock PZFI) and it would be a shame to have an external monitor that wouldn't allow me to remotely focus, so the VZ 7" goes back and it's a Marshall I'll be ordering today. Marshall makes (2) 7" models that list 800x480 rez: - V-R70DP which only has composite inputs and sells for $875 and; - V-R70P0-HDA, which has component, s-video and composite inputs for $1350 (B&H). On a side note, I looked at the Xenarc monitors David is linking to: These have VGA inputs only, not RGB component. So, unless there's an adapter to convert either composite, component or S-Video connections out of the HVX into a VGA connector, I don't see how that would work. (?) |
