Advice
I have been shooting with the firestore and I need advice on which mac I need to buy. I want to know if a dual processor 2.3 ghz with the stock video card (Nvidia 6600) would be acceptable to edit 720 24p files with minimal lag.
Any help would be great. Thanks |
Craig - I can tell you that I can edit 720 stuff easy as dv on a G4 1.67 pb.
So on a dualie 2.3 you'll be fine. 1080 yes, but it's not a lot of fun. I configure the pb into a dual bus external fw 800 raid to work with hd stuff. The only note of caution I'll throw into the mix for you - is the upcoming release of the Mac Pro, which you may want to wait for, but then again maybe you can't wait. If it was me I'd buy a refurb/used at the mom if I had to buy & hock it off when the new ones come out. Just a thought. |
the duocore laptop have more power than the desktop G5 now... Actual G5 will be discontinued soon. Wait for the new generation of Intel G5 or buy a laptop... pretty handy on the field! (I own a single core laptop pc and its work great!)
good luck! t ps: Conroe intel processor should be out in august if you can wait until then... mac will be in the first line for get it. |
Video caveat
Craig,
Keep this in mind when ordering your G5-based tower: The stock 6600 card is fine for 90% of any work you'll throw at the G5. However, if you plan on doing a lot of work in either Live Type, Motion or After Effects then you should upgrade the video card to the 7800GT for an extra $350. A little known but snarly fact about Apple and the 7800GT: You can only get that card as a custom configuration from Apple. You can't buy it later as an accessory, it's not offered. Well, actually you CAN get it as a stand-alone purchase however it will cost you $800 and there's only one place that sells it. The point being, order the card WHEN you order your new G5. Lastly: Regardless what video card ships with the G5 you can only get single-frame previews out to an external monitor via Firewire in any HD codec. You will need either a KONA or BlackMagic card if you want EXTERNAL real-time playback of HD content to an NTSC monitor. |
Video card is fine, except for using Motion on your target desktop |
Thanks Guys
I think I am going with the MacBook Pro. I wanted that anyways I was scared of the power though. |
